Old 08-22-2018, 11:29 AM
hellrace hellrace is offline
Default 6L90E reflashing
I have a 70 rs camaro with a lsa / 6L90e combo and I have just been out with the transmission to do some work to it after a had some noise from it I didn't like. Is it so that these transmissions need to be re flashed when the have been from the engine and had som work done to it ?
Guess there is some smart guys in here that knows this
Will trade wife for parts
Old 08-22-2018, 08:33 PM
shelteredV's Avatar
shelteredV shelteredV is offline
HP Tuners Pro and a good tuner should get the TCM acting nice. I'm new here, so don't want to open my mouth about tuners, just use one that is highly regarded because the trans is harder to get right than the engine.
The Following User Says Thank You to shelteredV For This Useful Post:
hellrace (08-23-2018)
Old 08-22-2018, 09:05 PM
If you didn't change any of the hardware (to be different from stock or whatever the last program change was), the situation is no different than unplugging your home computer. The machine does not forget basic operating parameters (program) when it is away from electricity for a bit. Just reconnect and boogie.
The Following User Says Thank You to rustomatic For This Useful Post:
