Old 06-18-2019, 12:20 PM
CCS's Avatar
CCS CCS is offline
Question 72 Nova Front end ask
Hi everybody,
Please, can you help me with?
Somebody has Tubular Control Arms + 2" drop spindles??
Can it be used like this? Is it possible to align with 15x8 rim wheels and 215/60R15 tires?
Thanks a lot!
1972 Chevy Nova
4 door sedan
350 sbc, TH350
Still stock rearend and suspension.
15" Ridler wheels
Old 06-24-2019, 08:06 PM
bretcopsey bretcopsey is offline
Several site sponsors advertize parts for 68-74 Nova (Speed Tech and Ridetech to name a couple) and 67-69 Camaro front suspension is the same in case you find something not marketed as “Nova.”
I think brake upgrades would be the limiting factor for your wheel size. If you plan to run stock brakes you should be fine.
The Following User Says Thank You to bretcopsey For This Useful Post:
CCS (06-25-2019)
Old 06-25-2019, 08:41 AM
BMR Sales's Avatar
you have to watch out - most Chinese A-Arms have a 2" Spring Pocket drop. When you add the Drop Spindles, you will be on the ground
CCS (06-25-2019)
Old 06-25-2019, 02:59 PM
CCS's Avatar
CCS CCS is offline
I'm foreign, then i can't see difference in just pics. All are similar looks.
Please help me, I want your front sway bar too. I have stocks springs and struts, 2" drop spindles, stock A arms, stock disk brakes.
Can I use a tubular arms?
1972 Chevy Nova
4 door sedan
350 sbc, TH350
15" Ridler wheels
Old 06-28-2019, 08:29 AM
BMR Sales's Avatar
Yes, you can use a Well Made set of Tubulars like ours.
CCS (06-30-2019)
