| onevoice |
04-20-2012 08:45 AM |
Originally Posted by Vegas69
(Post 408403)
Alston stuff is a couple rungs down the ladder and that's a FACT. I don't like the design and it's not engineered for the desired ride height of most pro touring cars. A triangulated 4 link is not ideal for our thin rails. Then Alston went and designed his G Link with no front crossmember so it doesn't tie in the rails nearly as well as a G Bar. The DSE upper shock mount not only allows for a lower ride height, but it reinforces the structure of the car and utilizes a panhard bar. I also don't see Alston out proving their products in our venue. For MOST guys, it's a great set up. It's just not on the same level.
I appreciate your opinion, but I don't think you are being fair about the comparison. I agree that any frame cracking is a serious issue, but have you noticed that DSE has also changed their panhard attachments to the frame?
I am not going to link pictures from their site, but look at the older version in the the Bolin68 album, then look at a later version with a boxed shock crossmember and vertical braces in the Kyle Busch album. They are very different. I also found a mention of DSE reinforcing frames on another forum. Because everyone is dealing with similar forces transmitted into thin framerails, my guess is that they also found cracking issues. As a point of reference, I had cracks develop in the front subframe of my 67 when I was frequently autocrossing it twenty five years ago. Racing breaks stuff. Given the power levels and tires available, anyone racing any suspension should be regularly checking all suspension attachments and links.
As to shocks, you can bet that DSE isn't running their standard package at shows across the country. Their upgraded double adjustables are a plus $1300 charge, plus another $150 to get poly link bushings that they recommend for competition.
The two suspensions were designed with different criteria, and have very similar performance when equipped comparably. I still think if you don't want to cut a huge chunk out of your floor for the crossmember, and still need to carry rear seat passengers ( ever sat on those upper link boxes?:D ), the g-link is the pick.
Make your choices and take your pick, but in the end, neither is junk, nor are either the absolute best way to attach a solid axle for racing.
