-   LSX Conversions (https://www.lateral-g.net/forums/forumdisplay.php?f=70)
-   -   PSI Conversion (https://www.lateral-g.net/forums/showthread.php?t=50836)
Vince@Meanstreets 08-30-2015 11:45 AM
Originally Posted by Swain (Post 615254)
Two rocker arms have bad bearing so in going to buy a new set and replace them all.
Anyone run roller rockers? Or should I stay with the stock style rocker arms with the Trunion kit?
Trunnion kit. we swap em on all ls
71RS/SS396 08-30-2015 04:41 PM
I would stay with the stock rockers in your case. We've seen failures with those too.
dhutton 08-31-2015 06:27 AM
So a brand new unfired GMPP crate engine had bad rocker arms right out of the box? That doesn't sound very encouraging..
Don
Swain 08-31-2015 07:07 AM
Don
The engine had 25-50 miles on it long story the engine was in a car that had a small fire. 1960 Chevy it was in caught fire but they got to it within a min or two so just the intake and other plastic parts were melted. The engine did have water in it for some time. Thinking now two lifters may be bad.
I'll order the Trunion kit anyway just to cross that out
Swain 08-31-2015 11:27 AM
could lifters feel spongy? Think they just need to build up pressure maybe from cranking the engine over and not starting all this time could of drained the oil?
Should I replace them dont really want to pull the heads
Vince@Meanstreets 08-31-2015 11:32 AM
:confused59:
Vega$69 08-31-2015 03:44 PM
The fire would have been helpful info to pass on when looking for help diagnosing the start up issue:headspin:
XLexusTech 08-31-2015 03:54 PM
:innocent: :ohsnap: :ohsnap:
dhutton 08-31-2015 05:39 PM
You should make sure you have good oil pressure before starting. LS motors can be difficult to prime. Remove the plugs, disable the ignition and fuel and crank til you have good oil pressure. This is quite important.
Don
Swain 09-03-2015 04:30 PM
Damn fix one this then another thing goes wrong.
My fuel pump wire lost power. Fuse is good relay is good. what the..............
