Beautiful work! If I may, I would offer one suggestion for the cage while you are at this stage. I would add a NASA/SCCA-compliant diagonal bar, just in case. The following is from the NASA 2019 rule book.
15.6.7 Diagonal Brace One (1) diagonal brace should be used in the same plane as the main hoop. The diagonal should be one continuous path; meaning that it must conform to Diagrams 15.6.7a or 15.6.7b. Note- If the installation method from Diagram 15.6.7b is used, the builder should pay close attention to alignment. One end of the diagonal brace shall attach to the corner, or horizontal part of the main hoop above the driver’s head, within twelve (12) inches of the driver’s-side corner. The other end of the diagonal brace shall attach to the mounting plate (or to the main hoop as close to the mounting plate as practically possible) diagonally opposed to the driver’s head (passenger floor). Pappy |
Nice work!
The new intake showed up yesterday and I thought you guys might like some engine porn! :hapdance:
https://live.staticflickr.com/65535/...4c2ff2b0_b.jpg20190613_185419 by Yelcamino, on Flickr https://live.staticflickr.com/65535/...ddc0f393_b.jpg20190613_185519 by Yelcamino, on Flickr https://live.staticflickr.com/65535/...9706d042_b.jpg20190613_185540 by Yelcamino, on Flickr https://live.staticflickr.com/65535/...6dd7e977_b.jpg20190613_185546 by Yelcamino, on Flickr https://live.staticflickr.com/65535/...f26d2015_b.jpg20190613_185626 by Yelcamino, on Flickr |
Very nice 👍
Isn't there a satin silver finish to put on that gold iridite oil pan to keep the color scheme the same top to bottom? This is going to have a ton of torque, I'll bet!
Looking Awesome Herb!
| All times are GMT -7. The time now is 02:52 PM. |
