-   -   Introducing BISKWIK (https://www.lateral-g.net/forums/showthread.php?t=59514)
Cramer4918 08-01-2023 06:36 PM
Originally Posted by syborg tt (Post 723682)
I would reach out to Boris at Street Machinery in Ohio as he would be the guy.
https://www.facebook.com/street.machinery
Tell him Marty said hi (( we sold him a 62 Bubble Top ))
Thanks, Marty! I will reach out to him. I'm excited to see you driving your Camaro soon my friend. :thumbsup:
Cramer4918 09-27-2023 11:16 AM
Hello Everyone!!! Very minor update. I have been working on getting the power brake setup mocked up. Here are my results so far.
https://uploads.tapatalk-cdn.com/202...0967db9360.jpg
Started with all this room!!!
https://uploads.tapatalk-cdn.com/202...e0eaebba34.jpg
Local hardware store only had 1/8” flat bar and since I have zero patience, I purchased it.
https://uploads.tapatalk-cdn.com/202...643bace5ae.jpg
It quickly turned into these spacers.
https://uploads.tapatalk-cdn.com/202...fb5173a041.jpg
https://uploads.tapatalk-cdn.com/202...85c5b01fa6.jpg
https://uploads.tapatalk-cdn.com/202...90f839abda.jpg
This is still the mock up phase. I am going to tack the spacers together and paint them.
https://uploads.tapatalk-cdn.com/202...0ce9e9b573.jpg
https://uploads.tapatalk-cdn.com/202...008a3206ba.jpg
https://uploads.tapatalk-cdn.com/202...5234f53291.jpg
So much better!!!! I will be making spacers to go in place of the washers at the brake booster. At the moment, spacing is perfect! I have full range on the pedal and I made it myself! [emoji1688]
Cramer4918 09-27-2023 11:26 AM
I also managed to get the battery charged up enough to get the motor primed and checked to make sure all my connections were good.
Pretty lights!!!
https://uploads.tapatalk-cdn.com/202...a7650e451b.jpg
I also completed my fuel system and made up a PTFE line to go from my stainless to the fuel rail.
https://uploads.tapatalk-cdn.com/202...4ac07fb163.jpg
https://uploads.tapatalk-cdn.com/202...f335cc7805.jpg
https://uploads.tapatalk-cdn.com/202...edd97c92e3.jpg
https://uploads.tapatalk-cdn.com/202...57b87ccf86.jpg
Cramer4918 09-27-2023 11:44 AM
1 Attachment(s)
It’s not pretty, but it’s complete!
syborg tt 09-28-2023 05:40 PM
Very nice.
Cramer4918 10-06-2023 05:21 PM
Originally Posted by syborg tt (Post 724182)
Very nice.
Thank you, sir!
I am adopting your approach to my build. I want to get it running and driving now. I will go back through it in the future and “refine” items as time and money allow. [emoji1688]
Cramer4918 10-06-2023 05:27 PM
Well… I made a little more progress.
I probably did not need to weld the spacer plates together, but I figured I could definitely use some more practice with welding. I know it’s not pretty, but I am still learning. I am using a flux core welder, so there is a copious amount of slag and spatter.
https://uploads.tapatalk-cdn.com/202...75f6cd1c63.jpg
I know you all are jealous of my high tech, high dollar welding table. When I am not needing it for welding, it doubles as a short step stool.
https://uploads.tapatalk-cdn.com/202...24a2e2f5e6.jpg
https://uploads.tapatalk-cdn.com/202...7d6bd57fcf.jpg
A little finessing with a grinding wheel and flapper disc and it doesn’t look too shabby….from ten feet at least.
https://uploads.tapatalk-cdn.com/202...156bb81fac.jpg
Cramer4918 10-06-2023 05:34 PM
Here are the spacers and bracket installed after painting.
https://uploads.tapatalk-cdn.com/202...9c9242d67e.jpg
https://uploads.tapatalk-cdn.com/202...da76eda059.jpg
Remember…. The bracket and linkage started off life as this…
https://uploads.tapatalk-cdn.com/202...1f6b2a79ff.jpg
I have to purchase a couple of fasteners and some SS brake line to complete the install. I will more than likely need a tubing bender as well.
Cramer4918 10-06-2023 05:49 PM
I was also able to get a replacement section of the underbracing for the hood from a member of one of the groups I’m in on FB.
Marty- I contacted Boris and he responded promptly. He has a lot going on and is just a bit too busy to look through his salvage parts. He was great to chat with and I appreciate the contact info though. Thank you!
Anyhow, this is what I am going to be repairing..
https://uploads.tapatalk-cdn.com/202...c0e7584b98.jpg
And, this is the piece I will be grafting from.
https://uploads.tapatalk-cdn.com/202...81b7bff423.jpg
I also went ahead and made a new ground for the battery. The previous ground was bolted to the frame in the rear. I cleaned up an area on the frame and welded a bolt directly to it. Once it was cleaned up and cooled, I taped the threads off and sprayed undercoating on the bare metal. I installed the new cable from BatterycablesUSA and I won’t have to worry about a dirty ground anymore.
https://uploads.tapatalk-cdn.com/202...7f8284b254.jpg
Old ground…
https://uploads.tapatalk-cdn.com/202...4ac1dc9f95.jpg
Cramer4918 10-06-2023 05:55 PM
Here’s a funny for you all….
I picked up a Neutral safety switch for the 4L60E and I decided to try to figure out the outputs for Reverse Lights. I spent about 45 minutes under the car with the switch installed, looking at a schematic and using a volt meter to determine what wires I need to use. I got that completed and wanted to see what color wires the reverse lights used. This is the “funny” part….. my car does not have any!!! :lolhit:
Nope. I did not know that. Something else to add to the list now.
https://uploads.tapatalk-cdn.com/202...0a054a6e10.jpg
https://uploads.tapatalk-cdn.com/202...b518a9b67c.jpg
Not even a hole through the trunk lid for one!
https://uploads.tapatalk-cdn.com/202...a3a483d409.jpg
That will be an adventure for another day.
