I looked back at my notes and my screws were 1.5 turns out. When I said a lean jet, I meant your actual main jets. They can cause a hesitation and a rich idle mixture will help. I found that my car needed a really agressive pump cam. I used the orange cam but it comes down to your own configuration. With an idle mixture that is to fat, you stand a good chance of fouling plugs. I'd see at what idle mixture screw adjustment get you to your highest idle and use that as your baseline. Then you can adjust accel cam and jets and tweak the idle mixture a hair if needed.
Look at the features on this page to see some of the changes: http://www.holley.com/0-80802HB.asp Even though it may bore you now that you're into techie-tuning. :mock: Quote:
In the backyard: http://sieg.smugmug.com/Motorcycles/...G%209562-M.jpg |
Maybe Davie if you work hard enough at your lucrative mod job Jody will give you a special one! http://www.desmonorthwest.com/forums...es/pictime.gif Skip - Is there is a smiley appropriate for you?.......maybe a string of them but certainly not a singular one. http://www.desmonorthwest.com/forums...walkingdog.gifhttp://www.desmonorthwest.com/forums...milies/ban.gifhttp://www.desmonorthwest.com/forums...ies/sign06.gifhttp://www.desmonorthwest.com/forums...stirthepot.gif http://www.desmonorthwest.com/forums...readjacked.gifhttp://www.desmonorthwest.com/forums...fighting72.gifhttp://www.desmonorthwest.com/forums...es/dousing.gif http://www.desmonorthwest.com/forums...es/muahaha.gif :cheers: |
Using squirters, springs, cams, floats, power valves, jets, and such seems so primitive and old fashioned....Lol. These days I call my tuner, we plug in the lap top, push a few buttons and I'm good to go. Seriously the new stuff is awesome :mock: Nice form on the trials bike :thumbsup: |
What happens when you can't reach your tuner and you have a corrupt map? :popcorn2: :mock: :popcorn2: Don't have much talent on the trials bike but I really enjoy it. :thumbsup: |
am I the only one that tunes by ear, butt and vac gauge?
I have never worried about turn count. Fetch a decent idle around 800, or till you read 0 hg at the venturi port. Register a slight idle circuit from the secondary blades. Turn the mixture screws in till you detect idle change then back out 1 turn. Then Butt tune the accel pump cams and squirters. |
:cheers: |
This is the best guide I have: http://www.holley.com/data/Products/.../199R10321.pdf |
| All times are GMT -7. The time now is 03:22 PM. |
