-   -   Norwood (https://www.lateral-g.net/forums/showthread.php?t=36443)
intocarss 02-17-2013 04:12 PM
Originally Posted by Ron in SoCal (Post 465319)
I dig your dog aventures and all Sieg, but I coulda done without that one. :poke:
I 2ND THAT
Originally Posted by Sieg (Post 465320)
Sorry life happens...........and my dogs ain't wearing undies. :D
:lmao: :lmao:
Originally Posted by Ron in SoCal (Post 465324)
Sometimes I don't either, but I aint posting pics :lol:
:thankyou:
"Run a straight boot on that cylinder and cover it with one of these or similar".
http://www.summitracing.com/parts/hsp-400204
^^^^ SIEG BABY Do what Rob suggested ^^^^
Sieg 02-17-2013 04:50 PM
Originally Posted by intocarss (Post 465340)
I 2ND THAT
At least I warned you guy's that there would be Toodles...........I guess just be thankful there not ours! :thumbsup:
GregWeld 02-17-2013 05:04 PM
Originally Posted by Sieg (Post 465315)
The boot is burnt to the point where arcing may be an issue.
Any clearance solutions much appreciated!
Connector, boot, shorty plug, clearance the tube, bendable sparky plug? :D
The Accel Shorty plugs are hardly any different than a normal plug... like a 1/4" shorter max.
The problem is the headers are for slant plug heads... and you're using straight plug heads.... the straight plug headers would extend further out before making the bend downward.
Try a narrower boot and then run a sock on it as well -- those boots are good - but they're also super fat.
intocarss 02-17-2013 06:25 PM
Originally Posted by Sieg (Post 465316)
Tucker scalped his toodles when he spun-out on the driveway the other day.
http://photos.smugmug.com/photos/i-z...-zrG2tQn-M.jpg
:confused59:
BTW Tucker needs a skid plate!!
GregWeld 02-17-2013 06:37 PM
:confused59:
At least he can lick his "wounds".....
Sieg 02-17-2013 06:41 PM
I think I would have been ok with 1 5/8 tubes, the 1 3/4" and less than optimal clearancing on that tube didn't help, thankfully it's the only one with issues. I can't believe you didn't angle plug heads in stock. :D
I measured an NGK plug I had and it was .25" longer than the Autolite, so the Accel at best is 1.75" which won't help.
MSD offers these race boots, I'll get both angles and see which provides the most clearance.
http://www.msdignition.com/Products/...t,_2/Card.aspx
http://www.msdignition.com/Products/...0,_2/Card.aspx
I may use the Moroso sleeves because the Heatshield Products sleeves are double layer which could be an issue. http://www.summitracing.com/parts/mor-71993
intocarss 02-17-2013 07:43 PM
How about a peice of header wrap safety wired on that tube in that spot? I may have a peice here or can get one. I may also have a couple of those plug boots
Sieg 02-17-2013 08:19 PM
The tubes touch each other and tube to boot clearance is so tight theres not much room. With the MSD grey boots it's a wedge fit until they get toasted and crumble.
Hopefully the angle boots work to keep the wire runs clean and since they sell the boots and sleeves in pairs I might as well do #3 cylinder since the boot just touches.
Here's my temp fix.
http://photos.smugmug.com/photos/i-Z...-Z6dxz3X-M.jpg
Really appreciate the offer, but I already have a list pending at Summit so I'll just add the boots. Besides you need all the time you can get to work on your brakes. :D
Rev says.........focus on your brakes Jerison!
http://photos.smugmug.com/photos/i-W...-WWMpfWm-L.jpg
intocarss 02-17-2013 08:50 PM
Tell REV I'm on IT :hello:
Sieg 02-23-2013 11:44 AM
It feels so wrong beating the ceramic coating off a new header. Wish Doug's would have pinched that tube .25" in the right spot. :(
http://photos.smugmug.com/photos/i-7...7vW4zGh-XL.jpg
Had to lay of the front fender and brace on the air cleaner to get the right angle, tight swing area, small hammer, 300+ blows equals decent forearm pump too. :sieg:
