-   -   Norwood (https://www.lateral-g.net/forums/showthread.php?t=36443)
Ron in SoCal 03-08-2013 09:27 AM
Green is better than Pink. Got it. :hello:
intocarss 03-08-2013 09:37 AM
And EFI is better then Carbs :hello:
Sieg 03-08-2013 10:09 AM
fleet 03-08-2013 10:58 AM
Originally Posted by Sieg (Post 469404)
That fool lets that happen to him...not this guy.
:D
intocarss 03-08-2013 11:57 AM
Track Junky 03-08-2013 02:03 PM
Have you tried bumping up the discharge nozzle size yet?
Sieg 03-08-2013 06:02 PM
Originally Posted by Vegas69 (Post 469384)
Mine came with Pink as well. It's for drag racing and absoutely horrible for throttle response. I'd jump up to orange as it delivers better volume on tip in..... I'm pretty positive that's the cam I used.
Money! Thank you. :thumbsup:
Still not ideally crisp but in the range now. The pump arm was at about .002 freeplay, I'll experiment lengthening/shortening the link +/- one flat of the nut and see if that helps.
:woot: :woot:
Sieg 03-08-2013 06:13 PM
No, but were getting there! 31's in it now, 33's and 35's are probably worth testing.
It felt pretty strong with smooth primary to secondary transition in 3rd & 4th gear hard roll on's this afternoon.
protour73 03-10-2013 06:41 AM
Sieg, here's great spec chart for Holley accelerator pump cams. The amounts are per 10 strokes of the pump arm and it is based on a 50cc pump, but is a good visual to see the differences when adjusting the cam position.
http://www.abodyjoe.com/pictures/Mis.../holley057.jpg
DaleTx 03-10-2013 09:05 AM
Originally Posted by Sieg (Post 469327)
Big flat spot (as I'd call it) no blubbering, then it's fine. If I rev it and don't let it come all the way down to the 1K idle, say 1500 rpm, and crack the throttle it's fine. This has all been while actuating the throttle by hand.
:sieg:
After reading this.... I was thinking maybe you should try advancing the cam a few degrees and see if the response off the bottom gets better. Maybe it's just a matter of changing the valve timing events slightly.
Just throwing out another thing to try.... not sure if you considered this or not.
