all the pics are of the pass side though and right now its sitting higher that the driver side by 1" the driver side rear height looks pretty good though. |
Lower control are Delalum bushings ATX Tall spindles from ATS L-2CAT5 Performance leaf springs S-13 Front coil springs C5 Corvette F&R calipers Baer Eradispeed rotors Quote:
Anthony-
This is why I didn't recomend a DSE 3" spring (beside the fact that the L2 CAT5 spring is much better in terms of construction): http://69.94.75.177/forum/showthread.php?t=40988 http://www.pro-touring.com/forum/showthread.php?t=18451 In that thread: DSE 3" drop leafs , early construction of car: http://www.t56kit.com/projects/padilla/27.jpg Same leafs, after constuction, and with a 1" lowering block: http://www.pro-touring.com/~tylerb/68Camaro.jpg Here is the 69 we are finishing on the Global West L2CAT5 spring- no lowering blocks, non full weight: http://i16.tinypic.com/8gjis7a.jpg We should be able to get Curtis' car plently low. Tyler |
I'm not worried at all. Tyler will be over in the next week or two and I'm sure he will be inspecting everything before the car hits the road.
Oddly, the drivers side sits a lot lower than the passenger. I may have to loosen the front bolt on that spring to get it to sit right. I'll post a picture of the drivers side tomorrow. It looks killer! :thumbsup: |
Yeah, in the thread Tyler linked, Jake said that all bolts need to be loose, get it on the ground, and then tighten it all down. You only redid the rear bolts today right?
Sounds like they are installed correctly, I guess it's time to see what happens when the rest of the drive train gets installed. :cheers:
I'm building a 355 street engine next week and thought I could cut him a smoking deal :) Can't wait for his car to get done... then we will have to find another Camaro or two in Vegas and come do a big ass photoshoot. |
Tyler, that black '68 looks great. Are those 17s or 18s on the car?
| All times are GMT -7. The time now is 08:22 AM. |
