-   -   Project 'Too Much': 1969 P1800S - soon to be P1800 GT (https://www.lateral-g.net/forums/showthread.php?t=34997)
krptonite 11-13-2012 03:43 PM
that will be tight with turbos! twin or single? i think you need the fbody set up as that puts the alternater down low and the ac is low on pass side, are you running the f body oilpan too?
daemon2 11-13-2012 06:22 PM
two turbo's, I have a few diagrams of the front accessory drives to measure it out to see what will fit; thanks for the tip on the fbody setup!
and yes I will be running the f-body oil pan.
I have some other work to do on the engine, more pics when I can.:thumbsup:
daemon2 11-30-2012 04:25 PM
stretch
lots of engine work right now and still stretching the body, its taking a bit of time but I want to make sure it flows nicely when its all finished.
This is before modifying the original panel:
http://www.daemoncustomauto.com/DCA%...rough%20in.jpg
and first attempt at the arches:
http://www.daemoncustomauto.com/P180...0flare%202.jpg
And now... Top of the rear quarter looking toward the back of the car with rough alignment:
http://www.daemoncustomauto.com/P180...0DS%20Wing.jpg
The transition is starting to look better:
http://www.daemoncustomauto.com/P180...0DS%20view.jpg
And the wheel clearance, wheels are about 2" below ride height in this image.
http://www.daemoncustomauto.com/P180...%20quarter.jpg
I am waiting for parts so I can put some time in over the holidays.
One more :)
http://www.daemoncustomauto.com/P180...ransitions.jpg
Thanks for looking!
krptonite 12-01-2012 06:19 AM
looking good!
daemon2 12-08-2012 07:53 PM
6 speed'ed'
T56 6 speed from a CTS-V
http://www.daemoncustomauto.com/P180...0driveline.jpg
I have a few options for drive shafts but for now I have converted the 3 spline output shaft to a 1350 flange yoke.
http://www.daemoncustomauto.com/P180...%20coupler.jpg
Showing half of the trans tunnel installed for clearance
http://www.daemoncustomauto.com/P180...test%20fit.jpg
http://www.daemoncustomauto.com/P180...rans%20clx.jpg
Happy Happy, but its feeling like Turbo Time
http://www.daemoncustomauto.com/P180...%20B8534T2.jpg
Royalworks 12-09-2012 11:12 AM
Ugh...Makes me want to work on my P1800. I finally got my wheels in the rear mounted. I'm jealous of these posts. Looking Good!
Royalworks 12-09-2012 06:17 PM
Just a tip. When i do metal fab and Im building something pretty much from scratch I'll use 1/8 or so metal round rod. I can bend it easily and it can show you the lines without building the entire panel and deciding it doesn't look good or you just wanted it a bit different. Plus you can tack weld your sheet metal right to it. You can build a whole panel this way. I know there are different ways to do it but I use this method.
daemon2 12-09-2012 07:04 PM
Thanks for the tip - I will give it a try!
daemon2 12-09-2012 07:08 PM
I noticed that little brown P1800 in the background of one of your build updates. Thanks for the compliment.
Royalworks 12-10-2012 11:12 AM
Yeah, its definitely in the background. I wanna just bust out the metal fab on it just so I can drive it. Lowering springs and metal work. Done. I doubt I will have the time to do what I really wanna do to it. For now I live vicariously through your build.
