-   LSX Conversions (https://www.lateral-g.net/forums/forumdisplay.php?f=70)
-   -   PSI Conversion (https://www.lateral-g.net/forums/showthread.php?t=50836)
Swain 10-08-2015 08:48 AM
Hooked up a NOID light this AM. The light comes on then never comes back. Seems like the injectors only get a signal for a second then goes away. I have sent the ECU back twice. I have a guy coming over Sunday to hook it all up.
We have added grounds everywhere. Cleaned off metal so its a good contact.
Vega$69 10-08-2015 10:00 AM
Ckeck the ignition relay on the psi fuse box.
Switch it with the fuel pump relay and see if the noid light works.
Pull the relay and check that you have 12v to it key on and when cranking.
Swain 10-08-2015 10:30 AM
Thanks for all the help. I just sent my Dad a text for him to try it. I will keep you posted.
Swain 10-08-2015 06:07 PM
She runsssssssssssssssss
Instagram. Jayswiz
cpd004 10-08-2015 06:18 PM
Instagram. Jayswiz
Congrats Jay.
XLexusTech 10-08-2015 06:32 PM
What was it?
Vega$69 10-08-2015 06:43 PM
Come on man. What was it?
Inquiring minds want to know.
Swain 10-08-2015 06:56 PM
Still gotta figure it out. I tried a little starter fluid and it fired right up. It won't start unless you spray just a tad. So maybe it needs a little start up tune
Swain 10-08-2015 07:38 PM
714-345-3875 text if ya wanna here a short clip
dhutton 10-09-2015 04:35 AM
Sounds like you do not have proper ECM voltage while cranking. Have you measured the voltage with a meter while cranking etc?
Don
