the housing will have Sway bar mounts on it. and at this point we thing a Factory sway bar will work waiting on one to arrive to test fit |
Any updates?
final Laser parts have showed up (they had a huge job that has slowed down delivery) we will weld up and start final install next week.
torque arm
Blake,
I have a Moser 9" in one of my third gens that i am in the process of needing to rebuild this winter as i blew a piston on my boosted LS3 this summer. Focus will be on the engine / t-56 trans but would like to improve the torque arm arrangement i have in this camaro, which is currently a jegster type short tunnel mount Would like to know if you will be just selling a torque arm and mounting arrangement i can mount to my existing 9" and then install appropriate front cross member?? i am very interested in your thread and 3rd gen suspension product development. your total set-up i am thinking about for a future 3rd gen project i have in mind. |
So if a guy was wanting to do it in stages it would be Mid section FIRST then either front or rear. As for your Moser 9 you would have to cut off all the mounts and replace with our mounts. |
I have a 9" Ford I'm building, just need to decide on who's full floater ends. So if I am reading your post right, You can install the mid and rear kits and leave the stock front end? And you will have the brackets to mount the torque arm?
Have you taken a measurement of how low the torque hangs off the axle to ground clearance yet? |
That is what we are planning
the torque arm is 2.25" below the bottom of a 9" housing. it posses no problems with clearance if that is what you were wondering |
Thanks for update, I can't wait to see the install pictures and then it out on a track performing.
Any updates?
I assume you're looking into converting to rack and pinion steering as well?
| All times are GMT -7. The time now is 06:17 PM. |
