-   -   Project 'Overtime': Pro-Touring 68 Acadian (Nova) with L92 swap (https://www.lateral-g.net/forums/showthread.php?t=14349)
scherp69 10-22-2009 04:54 PM
I also put on the Autokraft LS conversion motor mounts. I've seen them put on several different ways, but after confirming with Autokraft, these are the proper way of mounting them. The driver's side and passenger side are both marked, so unless you can't read, it's pretty straight forward. Also, they are designed that when the engine is sitting in the car, you should be able to read the writing on the side of the plates right side up.
http://i222.photobucket.com/albums/d.../PICT00744.jpg
This is with the motor upside down
http://i222.photobucket.com/albums/d.../PICT00753.jpg
Next came getting rid of the truck intake. If anyone is looking for one with drive by wire throttle body, I'm wanting to get rid of this one. Brand new, never been started.
http://i222.photobucket.com/albums/d.../PICT00763.jpg
http://i222.photobucket.com/albums/d.../PICT00773.jpg
Taped off the heads.
http://i222.photobucket.com/albums/d.../PICT00783.jpg
Next was to get rid of the ugly accessory bracket
http://i222.photobucket.com/albums/d.../PICT00823.jpg
Looks way better already
http://i222.photobucket.com/albums/d.../PICT00833.jpg
I then took the engine off the stand to start hooking up the scattershield and to dial it in.
http://i222.photobucket.com/albums/d.../PICT00852.jpg
http://i222.photobucket.com/albums/d.../PICT00862.jpg
The stock flex plate (also for sale if someone wants them as well as the stock exhaust manifolds)
http://i222.photobucket.com/albums/d.../PICT00872.jpg
http://i222.photobucket.com/albums/d.../PICT00882.jpg
http://i222.photobucket.com/albums/d.../PICT00922.jpg
You'll notice there is one bolt missing, that is for the dialing in process
http://i222.photobucket.com/albums/d.../PICT00972.jpg
That's where I got to today. I started to dial in the scattershield, but didn't have all the hardware to properly secure it to the block. I'm going to get the nuts and bolts in the morning and will hopefully have it dialed in. I will post pics of how to dial in the scattershield/bellhousing when I'm done.
70rs 10-22-2009 10:23 PM
It's looking great Mike! I like the look (with the door and fender mock up).
Do you not re use the stock TB off the factory intake? I thought you just transfer it over to the new one.
scherp69 10-23-2009 09:06 AM
Thanks Eric. I could have just taken the stock throttle body off and put it on the new intake, but I thought that since I have the 102mm intake, I'm going to get a 102mm throttle body to match. I'm waiting until spring to get it as that's when I hope to get more parts. By then, FAST may have a drive by wire one available. Right now I believe Nick Williams is the only one that has one. It's really nice.
waynieZ 10-23-2009 06:15 PM
Looks good . That Fast 102 intake is nice .
scherp69 10-31-2009 12:01 PM
Thanks Wayne. I think I'll be happy with that intake.
Originally Posted by TomM (Post 1211961)
Man how I do love LS porn.........great details....great write up....
BTW, I am diggin' the new wheels much better, not so blingy, and is going to look killer against that paint......not too much, just right.......post more when you can. I can't wait to see the FAST intake on there......:yes:
T,
Originally Posted by SoCal_63 SS (Post 1212053)
Nice work... dig the inspiration, and have to agree with the wheel choice also!
:yes:
Originally Posted by 19Novaman73 (Post 1215624)
can't wait for more pics on the motor:D
Originally Posted by Something69 (Post 1216085)
Looking great.
Thanks guys. I appreciate the comments. I can't wait to get this motor in, it will look so sweet against the apple red.
So a little update, a very frustrating one for me, but hopefully someone will learn from my mistake. I started dialing in the scattershield. First I had to buy a dial indicator and a magnetic base. Some write ups I read said you could use a 3" bolt and a c-clamp, but for $18 I thought the magnetic base would be easier. The dial indicator cost me about $20. You can also use a test indicator for this.
http://i222.photobucket.com/albums/d...9/PICT0098.jpg
I hooked the dial indicator up to the magnetic base and put it on the flywheel to give a good picture of how it looks without the scattershield on.
http://i222.photobucket.com/albums/d...9/PICT0100.jpg
The scattershield went on and I put the dial indicator back on the flywheel. Here's some pics of how it looks
http://i222.photobucket.com/albums/d...9/PICT0106.jpg
http://i222.photobucket.com/albums/d.../PICT01073.jpg
http://i222.photobucket.com/albums/d.../PICT01162.jpg
http://i222.photobucket.com/albums/d...9/PICT0114.jpg
After posting several questions on another forum, I found out this was not the right way to do it
http://i222.photobucket.com/albums/d.../PICT01082.jpg
It needs to be as flat as possible like this
http://i222.photobucket.com/albums/d.../PICT01102.jpg
Once the dial indicator was in place, I turned the engine 360 degrees and found the high and low points. My high point was at about 7 o'clock which put my low point around 2 o'clock. Your high point should be almost across from your high point. Once you get your high point and low point numbers, you take the difference and divide by 2. Then you get the off set dowels accordingly. For mine, I needed 0.0021 dowels.
Here's where I made a big mistake. It was recommend that I get some dowels from http://www.robbmcperformance.com/ but I thought "they're all the same and I can just get them in Canada and not have to pay the duty". So I had a pair of Lakewood ones shipped to me. They cost $19 for the dowels and $15 shipping. The Lakewood ones are supposed to turn using a screwdriver......I call bulls$*t. I'll get back to that in a minute.
So I finally got the new dowels
http://i222.photobucket.com/albums/d.../PICT00019.jpg
And it was time to take out the old ones. This was quite easy. I took off the exhaust manifolds as they're not being used anyways and used a long bolt. I then tapped them out with a hammer.
http://i222.photobucket.com/albums/d.../PICT00284.jpg
http://i222.photobucket.com/albums/d...PICT000412.jpg
http://i222.photobucket.com/albums/d.../PICT00079.jpg
scherp69 10-31-2009 12:02 PM
Now you want to put some grease on in the dowel holes and on the dowel and tap them in.
http://i222.photobucket.com/albums/d.../PICT00098.jpg
http://i222.photobucket.com/albums/d.../PICT00118.jpg
Before putting them in, look at them and find out where the high point on the dowel is, for both. You want to have them parallel in the block.
Here's where I was/am getting confused. My high reading was at 7 o'clock and my low was at 2 o'clock. I wasn't sure which way to point the dowels. After watching a video by Keisler, I found you want to point the high side of the dowel towards the biggest number you got with the dial indicator. This is because that number is telling you that it is 0.0035 (for example) away from the center. I think this is correct, but please if someone knows...correct me and help me figure this damn process out. I want to do it right.
So I went to try and turn the dowel with a screwdriver, like it said to do, and I'm not sure who was doing it, but there is no way in hell those things were moving. So I grabbed some vice grips and was able to turn them with those. I kept turning the dowels and remeasuring but ended up no farther ahead. The annoying thing is everytime you need to turn the dowels, you have to loosen all the bolts holding the scattershield, turn the dowels and then tighten them back up. On the passenger side I had no problem fitting the vice grips but on the driver's side, I had to cut out the mechanical linkage bracket. Good thing I'm going hydraulic.
Before
http://i222.photobucket.com/albums/d...9/IMG00050.jpg
After. I'm going to grind it down smooth and put some red paint on to clean it up.
http://i222.photobucket.com/albums/d.../PICT00263.jpg
That last picture gave a glimpse as to why not to use the 'screwdriver type' of dowels. You can only clamp them so many times before they end up looking like this
http://i222.photobucket.com/albums/d.../PICT00219.jpg
http://i222.photobucket.com/albums/d.../PICT00159.jpg
So basically I wasted $40 on dowels when I was told to get the good ones to start with. Take my advice....get the good ones to start with!!!
Yesterday I called RobbMC Performance and they will ship me a new set on Monday. The new dowels run $28 and the thing that pi****es me off...I paid $15 to have the first ones shipped from a place that is 3 hours away. RobbMC is charging $10 to be shipped from Nevada. The difference between the good ones and the Lakewood ones are that once they are in place, you can use a open end wrench to turn them. They also have a screw down the middle that allows you to loosen the dowels so they turn. Once in final place, you tighten the screw and they are locked in place. Here's a link to the good ones: http://www.robbmcperformance.com/products/dowels.html
Another thing I found during all the trial and error runs was that my magnetic base was not sitting completely flat on the flywheel. I could lightly touch the shaft on it and it would rock. I found out why. When it was sitting on the flywheel, the lip on the crank that comes through the flywheel (hopefully that makes sense) sits slightly higher, causing there to be a ridge. Also, the magnetic base would not sit flat between the two bolts as it was a little bit two wide. Nothing a grinder can't fix.
http://i222.photobucket.com/albums/d.../PICT00295.jpg
So today I am no farther ahead, but actually down $40 and a few frustrating hours. Hopefully next week I will get a chance to put the new dowels in and get this done once and for all. I just hope that I have all the kinks worked out and it goes smoothly.
Please if anyone has any suggestions or advice on dialing in the scattershield, please feel free to join in. I want this to be as informative as possible for anyone reading this.
70rs 10-31-2009 12:47 PM
Hey Mike,
I don't have any experience with what you are doing there so I can't help. But I can give you tons of credit and a huge thanks for posting all of this. It will without a doubt help me and I imagine many others when we go to tackle the same task.
It looks like you're on the right track now!:cheers:
70rs 11-15-2009 12:58 PM
It's been a while Mike. How are things coming along?
Did you have to remove the factory windage tray on the L92 when you used the Autokraft oil pan? There was a question from another member on that exact issue. :cheers:
130fe 11-15-2009 01:34 PM
Mike, what accessories are you going to use since you are keeping the VVT? I know the wegner setup gives you the option running either one. I am in the process of trying to decide whether to keep the VVT or remove it and make it an LS3 oon my L92.
