I know this is random, and u probably know this, but air pressure in the tires?
I went out and took a picture of mine. The wedge on mine is set up so the front of the axle is pointed down.... the opposite of what I see in your picture. The narrow gap between the leaf spring mount plate and axle is towards the front of the car on my car... on your car the narrow gap is towards the back of the car. Just an observation... maybe something to check. Here is a pic of mine with the narrow gap towards the front of the car... which makes the front of the axle point down. http://i1048.photobucket.com/albums/...ps4103fee4.jpg |
^^^ It does look like it's the opposite of yours Dale
Runout might be interesting thanks. Damn I wish I had a drive-on ramp right now........or even wheel stands! :bang: |
http://photos.smugmug.com/photos/i-W...WkMLDSJ-XL.jpg I'm not saying this is right but thats where we ended up when installing the trans with a drive on lift so I could determine the best angles given the setup. What bothers me is I made three 1* changes and there was no noticeable change. :headscratch: Realistically the biggest change from my baseline was the ring and pinion and new bearings. I'll check with Roy who did the setup in the morning and see what he thinks. |
1 Attachment(s)
Is the shim installed with the tapper towards the front of the car?? The yoke on the rear end should face down I'm thinking at least -3*..And the u joint is sitting all the way in the pocket (nice that you marked it)
I've got the routine down now so I can try zero wedge and 2* & 4* opposite of what I have and see what happens. Regretfull I don't have a convenient way to take accurate driveline measurements at this time. I'm wondering if changing out the rear shackle bushings to urethane impacted the angles? Or if the shackles are too tight restricting movement. They're torqued to 10 ft lbs. ??? Travel felt OK, turn-in and cornering stability definitely improved. |
Here's the info I used to set angles when I installed the T56:
http://www.iedls.com/asp/admin/getFi...&TID=28&FN=PDF I used the example in Figure 5 I'm wondering if the urethane bushings I installed in the rear shackles at the same time are too tight and binding thus effecting the pinion angle. I torqued the uppers at 5 lbs, could get the torque wrench on the lowers so they're by feel. :headscratch: |
Yes -- should have been is NOT down.... |
| All times are GMT -7. The time now is 05:07 PM. |
