| ProdigyCustoms |
08-26-2007 05:05 AM |
Now surely this cannot be a shallow hole / deep hole problem (Keep your mind out of the gutter now!). The brakes would not work if that was the case. It is possible but no likely the rod is a tiny bit to long for the hole (watch it now!). This is very easy to verify, when you put the master on, pushing it tight against the booster, if the master springs back at all, the rod is to long or the hole is too shallow (I know, happens to us all the time!). The quick test / fix is to put a couple washers between the master and booster to shim the master away a bit to see if this stops the problem. I doubt very seriously this is going to be the problem though as those guys surely know all this.
Another thing to check though that if could be is to make sure that at the retun line TEE for the hydrobbost / Power Steering, that the brake return side of the TEE is on the straight through side of that TEE. If the brake side is not on the straight side of the TEE, this could prevent the booster from returning fluid fast enough, and making the brakes feel a bit hung (Here we go again).
