-   -   Project "Battle Wagon" (https://www.lateral-g.net/forums/showthread.php?t=26421)
Rick D 04-30-2012 09:36 PM
Yuuupp :yes: That's what I was thinking but I was thinking in the trunk drop, will see when I'm further along.
CamaroAJ 05-01-2012 12:51 PM
i thought about that area too. i have a rear firewall and most of the openings are blocked off so it might not work for me. you will need to build a shield for it if you put it back there though so water and grime from the tires doesn't get into it.
CamaroAJ 05-01-2012 09:51 PM
Got the drivers door latch done yesterday night.
http://a1.sphotos.ak.fbcdn.net/hphot...22260380_n.jpg
http://a4.sphotos.ak.fbcdn.net/hphot...11626700_n.jpg
After a lot of measuring and test fitting floor mount pedals it just wasn't worth the time and effort to get the pedals to fit right AND be comfortable in the seat. I said screw it and decided to modify the stock 4th gen camaro pedals. as it turns out it was easier to do than i thought it would be. Still have to mount the clutch master cylinder and gas pedal.
brake and clutch pedal mocked up
http://a7.sphotos.ak.fbcdn.net/hphot...32043885_n.jpg
Power brake booster mounted
http://sphotos.xx.fbcdn.net/hphotos-...54508884_n.jpg
Engine set so far back the brakes are almost next to the alternator
http://a1.sphotos.ak.fbcdn.net/hphot...80597795_n.jpg
Pedals modified to accommodate the seat moved back.
http://a4.sphotos.ak.fbcdn.net/hphot...89740649_n.jpg
Hoping to have the gas pedal mounted tomorrow.
CamaroAJ 05-07-2012 09:07 PM
got the pedal mounts done.
http://sphotos.xx.fbcdn.net/hphotos-...59932694_n.jpg
and then built a box to mount the stock GM clutch master cylinder inside the car since i moved everything back.
http://sphotos.xx.fbcdn.net/hphotos-...37762992_n.jpg
master box mounted
http://sphotos.xx.fbcdn.net/hphotos-...04309310_n.jpg
pedals done. modified a '57 chevy gas pedal. not sure why the clutch pedal looks funny in this picture.
http://a1.sphotos.ak.fbcdn.net/hphot...13721548_n.jpg
corvette engine stands and mounts showed up so this will be the next project.
http://sphotos.xx.fbcdn.net/hphotos-...11921995_n.jpg
coolwelder62 05-08-2012 05:15 AM
I like want you are doing.Very nice fabrication.:thumbsup: :thumbsup:
CamaroAJ 05-28-2012 08:09 PM
Thanks!
got the driver striker and vent filled.
http://sphotos.xx.fbcdn.net/hphotos-...22428593_n.jpg
then got the new engine cross member built. I'm very happy with the way this one came out. notice the notch for the oil drain plug. also the bolts are recessed on the bottom so they don't hit.
http://a2.sphotos.ak.fbcdn.net/hphot...03369016_n.jpg
driver side
http://a5.sphotos.ak.fbcdn.net/hphot...67900011_n.jpg
passenger side
http://sphotos.xx.fbcdn.net/hphotos-...87816928_n.jpg
got the roof stripped
http://a8.sphotos.ak.fbcdn.net/hphot...65192753_n.jpg
and the body work has been started
http://sphotos.xx.fbcdn.net/hphotos-...56703044_n.jpg
http://sphotos.xx.fbcdn.net/hphotos-...87841207_n.jpg
cut out the factory transmission cross member notches
http://sphotos.xx.fbcdn.net/hphotos-...49279997_n.jpg
http://sphotos.xx.fbcdn.net/hphotos-...70905403_n.jpg
used the slip roll and bead roller at my buddies shop and bent up the new fill panels. the kick out on the passenger side is for the reverse switch on the transmission.
http://sphotos.xx.fbcdn.net/hphotos-...96150782_n.jpg
http://sphotos.xx.fbcdn.net/hphotos-...86685855_n.jpg
intocarss 05-28-2012 11:28 PM
Just read your intire build. Awesome job!! :thumbsup:
waynieZ 05-29-2012 10:22 AM
It looks great, nice work! I like what you did for the front crossmember.
CamaroAJ 06-18-2012 08:38 PM
thanks guys. waynie, I'm a lot happier with this cross member than I was with the other one. the round tube just didn't look right with all the square tube in the speedtech sub frame.
got the interior epoxy sealed.
http://sphotos.xx.fbcdn.net/hphotos-...54709779_n.jpg
http://sphotos.xx.fbcdn.net/hphotos-...47682106_n.jpg
then I got a hold of a rotis to flip the car over.
http://sphotos.xx.fbcdn.net/hphotos-...36005541_n.jpg
repaired some more rust on the passenger tulip.
http://sphotos.xx.fbcdn.net/hphotos-...18933649_n.jpg
then decided to move the accusump to another location and fabbed up a new filler with a X and a recess for the A/C bulkhead.
http://sphotos.xx.fbcdn.net/hphotos-...09256327_n.jpg
using a corvette fuel filter/regulator and put it where the factory spring pockets used to be.
http://sphotos.xx.fbcdn.net/hphotos-...86663469_n.jpg
then got the bottom fully ready for epoxy.
http://sphotos.xx.fbcdn.net/hphotos-...28663419_n.jpg
and half the inner roof ready too.
http://sphotos.xx.fbcdn.net/hphotos-...66471413_n.jpg
and the start of real color on parts of the car. I used the stock valve covers and cleaned them up.
http://sphotos.xx.fbcdn.net/hphotos-...41911030_n.jpg
The bottom will be sealed tomorrow night and then depending on weather there might be some body work started on the bottom or it might have to wait until wednesday night.
Rick D 06-19-2012 03:43 AM
Looks real nice AJ, won't be long now! :thumbsup:
