-   -   Chevelle 2.0 (https://www.lateral-g.net/forums/showthread.php?t=56034)
Yelcamino 07-25-2020 03:04 PM
Originally Posted by WSSix (Post 705212)
My assumption was that it was a tight fit but I wasn't sure. Thanks Herb.
No problem Trey! :thumbsup:
Yelcamino 07-25-2020 03:05 PM
Originally Posted by payne (Post 705280)
Are your brake ducts going through the frame? If so, as one piece or do you have a coupler through the frame and attach the flex hose on each side of the coupler?
Love the build!!!
Yes they go through the frame via a piece of 3" tubing welded in place. The hoses then attach on either side.
Thanks! :thumbsup:
Yelcamino 07-31-2020 09:20 AM
It's been a busy week! I installed the headers and they fit like a glove! So happy how they turned out. Next on the list was to make the connections from the headers to the exhaust. That's all done and the only thing left is to have thermal barrier coating applied at some point.
https://live.staticflickr.com/65535/...992cb271_b.jpg20200725_165109 by Yelcamino, on Flickr
https://live.staticflickr.com/65535/...eea4d4fd_h.jpg20200725_163209 by Yelcamino, on Flickr
I've also been chipping away at plumbing and wiring. I'm waiting for some fittings to finish the power steering lines and I think plumbing is done. Wiring is at the beginning stage. Battery cables are in place and most of the EFI harness is in. Slow progress, but at least it's progress.
https://live.staticflickr.com/65535/...3885a9db_b.jpg20200729_191840 by Yelcamino, on Flickr
https://live.staticflickr.com/65535/...cbde9b2c_b.jpg20200730_182312 by Yelcamino, on Flickr
ScotI 08-01-2020 11:13 AM
What the consensus on running BATT cable & fuel lines when relocating a battery?
I always thought they're ok on the same side as long as each was positively secured but I've read where others say they should be ran on opposing sides of the frame. I can see where 'opposing sides' would ultimately be safer (given the distance between) but not sure of the likelihood they would only cross somewhere else.
Yelcamino 08-01-2020 02:26 PM
I don't know what other people do, but I route everything as safely and securely as possible. My fuel lines are inside (most of the way) steel tubing and the battery cable (only hot when cranking the engine) has grommets everywhere it passes through steel. Once I'm done under the car, the belly pans will be installed adding another layer of protection.
Yelcamino 08-14-2020 06:26 PM
Here's a fun update! :popcorn2:
214Chevy 08-14-2020 07:48 PM
Sounds good!! Nothing like hearing your engine for the first time.
jarhead 08-15-2020 07:21 AM
I like the size of these pictures. Much better than instagram on a phone.
ScotI 08-15-2020 10:24 AM
x2. Agreed!
WSSix 08-15-2020 02:16 PM
Congrats, Herb. The car sounds amazing!
