-   -   Introducing "TRACKDAY", 1968 Camaro (https://www.lateral-g.net/forums/showthread.php?t=10706)
intocarss 01-27-2013 05:11 PM
Originally Posted by sik68 (Post 416412)
Thanks all!
Matt & all I will let you know what I find on the c-clips. I would be so stoked if they mitigate the knockback issue. I read a post from David Pozzi a long time ago about the Trans-Am cars putting valve spring shims against the c-clips to shim out end play....so it must count for something.
I searched but couldn't find that post from D Pozzi. Do you happen to have a link to that? I got 0.25 play
Sieg 01-27-2013 05:24 PM
Originally Posted by sik68 (Post 460577)
LOL no comment. Let's just say she doesn't think primer is a color.
Huh? It's the color of the sky............8 months out of the year in Oregon. :D
Good job on the truck, not money you wanted to spend but it needed to be done. :thumbsup:
sik68 01-27-2013 07:27 PM
It was probably on camaros.net. If I don't find it first....
intocarss 01-27-2013 10:07 PM
Thanks. I think I found it
http://www.camaros.net/forums/archiv...p/t-27943.html
Your problem might be excessive end play in the axles. The same problem happens with JL8 conversions.
Try shimming behind the C clips with a spacer. I've heard a valve spring spacer with a little filing will work well.
Get the end play close to zero. If you go too tight it may affect the positraction function.
What size are the rotors in dia and width?
David
Yes, put the spacer between the side gear and the C clip. You will need around .015" to .030" thick shims.
There used to be thicker C clips to do this but I don't think they are available anymore.
If you go too thick you may prevent release of the positraction.
Non posi rears are looser than the posi type, which would knock the caliper pistons back even farther.
David
David Pozzi 01-27-2013 10:43 PM
The "right" way is to place shims between the carrier housing and the clutch plates. Extra shims are in a rebuild kit and you might be able to get just the shims from a Differential parts store.
http://www.carcraft.com/techarticles...ted_slip_posi/
David
intocarss 01-28-2013 08:18 AM
David
Thank you :thumbsup:
Found this too
https://www.youtube.com/watch?v=CGq15JBBUQw
https://www.youtube.com/watch?v=UwxLHFZq6QA
