-   -   Project "Battle Wagon" (https://www.lateral-g.net/forums/showthread.php?t=26421)
dug 06-19-2012 07:37 AM
beautiful work. not to mention you're hauling ass.
next69 06-19-2012 09:27 AM
How long did it take to upgrade to the newer door latches?
CamaroAJ 06-19-2012 07:57 PM
thanks guys, its coming along pretty fast right now.
next, it only took an hour or two for both of them.
its got two coats of epoxy on it now.
http://sphotos.xx.fbcdn.net/hphotos-...84747787_n.jpg
http://sphotos.xx.fbcdn.net/hphotos-...04077144_n.jpg
next69 06-20-2012 09:44 AM
I would assume beyond the obvious visual improvement the doors are probably much nicer (less resistance and quieter) to close. Is that accurate?
CamaroAJ 06-20-2012 01:29 PM
They are pretty easy to close yes. I don't have any weather striping yet and the doors are empty so they sound tinnie. I think that will go away once it's all finial assembled.
CamaroAJ 06-27-2012 09:31 PM
We started the body work on the firewall, it need a skim coat and sanded then it's ready for primer then work will start on the bottom side of the floor.
http://sphotos.xx.fbcdn.net/hphotos-...46668156_n.jpg
Bent up the steam tubes.
http://sphotos.xx.fbcdn.net/hphotos-...10066788_n.jpg
Got a lot of the parts back from paint, reassembled the throttle body.
http://sphotos.xx.fbcdn.net/hphotos-...95163294_n.jpg
Modified the slot in the bottom of the factory frame rail to put my corvette frame pucks in so I don't chip the paint on a lift.
http://sphotos.xx.fbcdn.net/hphotos-...23973002_n.jpg
Tig welded a 1/4" round rod frame then welded it into the trans tunnel to stiffen the hole.
http://sphotos.xx.fbcdn.net/hphotos-...34305965_n.jpg
Fabed up a new passenger side fender mount out of 3 pieces of 16g steel. Not bad for a body hammer and a body dolly.
http://sphotos.xx.fbcdn.net/hphotos-...20311188_n.jpg
waynieZ 06-27-2012 10:08 PM
Very Nice work!
Ron in SoCal 06-27-2012 10:56 PM
Great idea on the frame pucks. I thought about that one too...:thumbsup:
CamaroAJ 07-11-2012 10:28 PM
while it doesn't appear that there is a lot done (at least to me anyways) i have been doing a lot on the car that i am just not going to show until the car is done as some of it might make it into a production run.
machined some bulkheads for the passenger side brake line and the driver side brake, fuel and return lines.
http://sphotos-a.xx.fbcdn.net/hphoto...96461108_n.jpg
http://sphotos-b.xx.fbcdn.net/hphoto...36334905_n.jpg
http://sphotos-b.xx.fbcdn.net/hphoto...08833415_n.jpg
then finished the fuel lines back to the fuel cooler and trunk bulk heads and the brake lines.
http://sphotos-a.xx.fbcdn.net/hphoto...86365141_n.jpg
http://sphotos-b.xx.fbcdn.net/hphoto...83862425_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...41368713_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...46956114_n.jpg
the rear sections of fuel lines are covered in heat tape then cloth heat shrink.
http://sphotos-b.xx.fbcdn.net/hphoto..._7953591_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...97515672_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...66508192_n.jpg
then i started mounting the diff. cooler. there will also be a trans cooler on the other side in the same place.
http://sphotos-a.xx.fbcdn.net/hphoto...31387557_n.jpg
Rick D 07-12-2012 05:09 AM
Looking good AJ :cheers:
