-   -   1967 Camaro Build - Houston, Texas (https://www.lateral-g.net/forums/showthread.php?t=56664)
Beechy 10-04-2019 06:02 PM
Good lookin' ride
Brian, congratulations on completion, great color/wheel combo. Enthusiastic pit crew!
Question (not complaint) : how come so little caster? I would have thought at least 4* if not 6*? Seems like the alignment shop has used generic 68 Camaro reference data (which gives the red and green highlights) rather than contemporary set-up numbers?
Do you know the specs from your front clip vendor?
Brianstanford 10-04-2019 07:07 PM
thank you! wheels ended up matching by luck lol. found them used on craigslist after i picked the body color
front subframe is stock, with a ridetech level 2 kit. handed the ridetech instructions to the alignment guy and said this is what i need
from my instructions when i bought the kit in 2015 - Have the alignment shop set the car with ½ degree negative camber, 2-3 degrees positive caster, and 1/8” toe in.
double checked my instructions with what is online now 2019 and they are different.....now online - Have the alignment shop set the car with ½ degree negative camber, 3-5 degrees positive caster, and 1/16”-1/8” toe in.
Beechy 10-05-2019 01:47 AM
This caster setting sounds better.....assuming the arm geometry is the same as yours (same part number upper and lower wishbones) this will give better turn-in, slalom and high speed stability.
Brianstanford 10-05-2019 01:53 AM
What about tire wear? Car will be 100% street use for now, no foreseeable track use
dhutton 10-05-2019 06:57 AM
I would add a little more negative camber to help avoid any tire rubbing. -.5 degrees is good imho.
Too much caster can result in a fair amount of jacking. I had quite a bit of caster with my Ridetech Tru-Turn setup and the steering joints were groaning when I turned the wheels. Those heims are not very forgiving of dust etc imho....
Don
Brianstanford 10-05-2019 01:54 PM
1 Attachment(s)
Don
Already had some rubbing. Replaced the outer fender bolts with button heads and made some room with some hammer taps. No more rubbing
will69camaro 10-05-2019 02:15 PM
I did the same thing.
There is a classic car cruise on 20th if interested.
dhutton 10-05-2019 03:53 PM
Add some negative camber for increased margin.
Don
Beechy 10-05-2019 04:15 PM
Caster
99% of driving miles are run straight ahead, caster doesn't affect the angle of the tire relative to the pavement, so does not affect wear. It DOES improve stability and "return-to-center" after turning.
During turns, caster tilts the outside wheel inboard at top so preventing tire "tuck under" thereby improving tire life.
Extreme caster (8* and more) will cause tire wear and is too much on a wet road with low profile tires.....car will PUSH BAD.
Four degrees is very conservative.
Everybody needs "slalom" when that autonomous Tesla comes out of the side-street.......not just for autocross guys.
VERY simple explanation (there are other factors at work)::::Caster is the difference between shopping cart wheel flutter, and a bicycle when u push it along using the seat only. Caster being the angle of the head stem where the steering bearings are.
Brianstanford 10-05-2019 08:13 PM
Where at? Give me some details please
