And here I thought I was the only one to do that... :underchair: My hard lines on my axle tube are beat to hell after 5 years of exhaust hitting them, tie down straps, and just general abuse...plus I've never replaced the soft line from the chassis to the axle. I like the solid line to the frame rails and soft lines down to the caliper option, I'm going to look to see if that is possible for me when I redo my back lines. IF it's possible routing wise, sure seems like a better option than running them along the axle tubes. |
Sieg, Right Stuff Detailing has the brake line armor or spring wrap you're looking for.
Tu, it does make it more of a pain for servicing to have hard line going to the individual calipers, but if you design it with a bend in the line and maybe an easily removable hold down near the caliper, it's not so bad. C2/3 Corvettes were this way stock. |
You definitely want soft line from the end of the axle to the caliper. That is, unless you like to bleed brakes every time you pull a caliper.
Caliper and drop flex lines, rock guard sheath on order.........
and......... GW Del-a-lum upper and lower control arm bushing and offset control arm shafts. Quick Fuel 5.5 and 6.0 power valves and set of Buna rubber float/metering block gaskets. Damn, even Pro Tinkering is getting expensive! :D |
"Project creep"... or also known as "WhileImatititis"
Next thing you know you'll be pulling the engine to detail the front suspension in a project that started as a simple electric fan install... ;) |
It's not a f'n pseudo Black race car.... how often do you think he's going to drop the caliper to change pads? He lives in the PacificNorthWET -- SOB car doesn't get 1500 miles a year.... |
I learned to like things serviceable with my wannabe race car. I also learned to do it right the first time. :mock:
Thanks for making my point --- that's 10 years worth of driving before needing to replace the pads. And you're not tracking it (yet).... so it's just street driving. I just don't see the need to make it that serviceable any more than a stock application. BTW - you should bleed the brakes on a car like this about once a year since the fluid is hygroscopic and absorbs moisture - even more so where you live.... There! I got the last word! LOL |
| All times are GMT -7. The time now is 11:30 AM. |
