| The WidowMaker |
03-22-2011 06:10 PM |
thanks for the comments guys. i got one side of the hood done and am about 80% done with the other side.
What is this port for and where does it connect on the motor? I have a smiliar radiator and don't know where to hook it up.
What are the other two ports for? Oil cooler?
its for the steam port. i didnt do enough reading before i set this up, but it appears that some guys have a way around running the line from the head to the radiator. id have to find the info, but i think they are tying it into the water pump. if thats the case, i'll just plug it.
the other two are for the internal oil cooler with -10 fittings.
Wow, you are doing a killer job man. Went to the magnum A?
yeah, and i blame you and dave :thumbsup:. by the time i spent the money sending it to liberty i was in magnum territory. i just wish tremec would have had it 3 years ago when i got the tko. i was looking at a modded t56 at the time and those were BUCKS.
im not too worried about fit since my tunnel should be large enough, but im going to have to come up with a new mount on a freshly painted frame.
