-   -   Chasing the Ghosts of LeMans - Thunder - Project 487 Super Snake (https://www.lateral-g.net/forums/showthread.php?t=37762)
Ripped 07-17-2013 06:21 AM
Originally Posted by FETorino (Post 493796)
Cool. One step closer.:gitrdun:
Whose Alt bracket is that?
:cheers:
The pulleys and brackets are from http://www.cvfracing.com/
I am pretty happy with them so far. Some fitment issues, with the head, block and intake manifold position.
Originally Posted by Flash68 (Post 493797)
Congrats!
Love the motor... but I really dig the vintage fridge in the background. :D
Ha ha, thanks, yeah kinda going for the retro look in the man cave/ garage.
Free beer for help LOL (good Canadian beer!)
Rybar 07-17-2013 11:26 AM
Cool updates Doug, hope you get it together soon!
Ripped 07-18-2013 11:05 PM
Thanks Ryan.
Things are coming together much more slowly than anticipated.
She's fighting me. I spent a full night with the new pulleys, and I still have one more fan belt to size, and one adjustment sleeve to order.
Tonight was much more productive.
As anticipated the old mini starter would not fit with the aluminum block. The pre-ordering of the MSD starter was a good idea, and pretty much bolted right in. Plus the wiring location is better than the old starter.
So flywheel, clutch, pressure plate, t/o bearing, engine wiring, pressure and temp switches, sending units, rad hoses, water fittings, and mocked up the headers, for a look see.
I am bagged after two long nights, but am thinking, if I have a good night, I could get it all in the car and running tomorrow.
That's the goal.
FETorino 07-19-2013 11:07 PM
That's the goal.
Tomorrow is today Doug.
Where's the video of you firing it?
:cheers:
Ripped 07-19-2013 11:40 PM
3 Attachment(s)
All the best laid plans ;)
Tonight the carb was fighting me. I was hoping to drop it down and use the cobra oval. All the work for not.
The flip side, is I ended up using the (higher torque) quick fuel 1" spacer, and the special ultra low drop base air cleaner, that I had the foresight to order.
That will get me started anyway.
Finally fitted an a/c fan belt that works. Plugs are wired, swapped out the red msd cap for a black one, fuel lines, & return springs are installed.
Seems like a lot of hours for not much in the way of results.
I have to extend the solenoid trigger wire, and it "should" be ready to drop in the hole.
Ripped 07-20-2013 09:26 PM
Whew
14 hours of work and a big thank you to my wife for putting up with my determination to get her in and running.
Every step of the way was a battle. Considering that I've done this multiple times before, and that I had everything set up, it should have been easy, right?
Wrong!
From motor mounts, headers, spitting out all the needle bearings out of a u joint, to a nice fuel leak plus a multitude of things along the way, it was rough, and tiring.
BUT she fired right up.
I have to adjust the clutch. AND there are a few details to finish up.
Hoping to be road worthy tomorrow.
FETorino 07-20-2013 11:11 PM
Great news Doug.:thumbsup:
I'm rooting for you to be driving tomorrow.:rockin:
Even in grocery getter trim she sounds dam good.:P
:cheers:
Ripped 07-21-2013 05:21 PM
:cheers:
Thanks for your support.
It looked dicy this morning. I got the clutch adjusted, and then while driving it up the lane by my house it dies.
I couldn't get it to start, and there was a puddle of what looked like oil, under the car!:censored:
I was freaking out.
After going through the basic checklist, it turns out I over filled the power steering pump <whew>
And I had spark, so the carb was the next thing.
Rear float was badly out of adjustment, and was flooding the engine.
After an hour or two, of f-ing around, I got it working better.
I was out driving it today. It's a little rough, and honestly should have the carb set up to the car, and dizzy checked but it drove pretty good.
I nailed the alignment and ride height, even centered the steering wheel perfectly ;)
It's F-in LOUD!
I didn't realize when I test drove it yesterday I had the baffles in the exhaust completely closed! When I opened the exahust through the mufflers, holy S#!T! It sounds like... well, I'll put up another video soon. I might as well throw the stereo system in the garbage. Cars were literally trying to avoid being beside me at stop lights!
Anyway cheers and thanks for the support. More driving to do!
Ripped 07-21-2013 08:40 PM
1 Attachment(s)
No... no video.
After the 2nd day of driving the car, and getting all the kinks out... this happened;
:censored: :censored: :censored: :censored: :censored:
The brand new edit - was not the MSD starter it was fine - and battery was fine except for the melted terminal /end edit
Lucky I had the foresight to check and disconnect all the VERY HOT smoking terminals before it caught fire.
Wondering if this bad luck is going to stop at some point?:bang:
Going to the gym now to release some frustration! :censored:
390 S code 07-22-2013 03:03 AM
Doug ,sorry to here of your misfortune , your quick actions certainly saved your car . On my car I have a optima as well and I have fitted a 300 amp fuse which sits between the positive threaded post terminal and the cable lug . My brother who has a marine electrical business will not have any circuit not protected I will try and post a photo of it .
