-   -   Norwood (https://www.lateral-g.net/forums/showthread.php?t=36443)
Sieg 03-20-2015 01:19 PM
Originally Posted by intocarss (Post 599440)
RIPPING IT ALL APART.......Are You Bored??
Not bored by any means..........scared would be a more accurate description.
http://photos.smugmug.com/photos/i-W...-WhCz62W-L.jpg
http://photos.smugmug.com/photos/i-p...-p6jsc8C-L.jpg
http://photos.smugmug.com/photos/i-w...-wVTPPJD-L.jpg
:D
Panteracer 03-20-2015 01:45 PM
Norwood
Yes I would say it is time for some bushings and rubber pieces
They are older than most on this forum.. kinda like some very
low mileage Panteras that have much of the car just waiting
to fall apart but some investor type spends big bucks because
of the Odometer readings...
Bob
efs69 03-20-2015 06:00 PM
Originally Posted by Sieg (Post 599439)
Were you using stock or aftermarket control arms?
Currently my top of wheel opening to ground measurement is 24.25", with no header clearance issues.
I'm thinking spacers will may be needed.........or a money tree and a hybrid coilover setup.
http://photos.smugmug.com/photos/i-v...vzVfF47-X2.jpg
Scott that is a damn fine car you have there!!!
I had stock control arms first and I was about an inch lower about 23 inches. Then I switched to SPC upper and lower and it went down another inch because the lower had a dropped pocket.
Roberts68 03-20-2015 06:44 PM
I think Global West has a 1" drop spring.
Here's mine with stock UCA/LCA and 2" drop Hotchkis. http://i40.photobucket.com/albums/e2...0881559486.jpg
Panteracer 03-21-2015 10:45 AM
Norwood
My buddy Harry who worked with Herb Adams
Told me they would slope the spacers on the subframe
Medium at the back, smaller in the middle and none
Up front. Frame stayed the same so no header issues
but everything else is lowered
Bob
Sieg 03-21-2015 10:18 PM
Thankfully I enjoy shop time, but I wouldn't exactly call the last couple of days fun.......
http://photos.smugmug.com/photos/i-C...CS8nd9s-XL.jpg
No stiction here......
http://photos.smugmug.com/photos/i-8...8Khs3FF-XL.jpg
Smoothed all the edges on the upper and lower control arms.
http://photos.smugmug.com/photos/i-h...hJnD3dq-XL.jpg
http://photos.smugmug.com/photos/i-P...PdMQL4R-XL.jpg
Anti-roll bar link holes were elongated on both arms, so a quick fix ensued.
http://photos.smugmug.com/photos/i-p...pXmnd7G-XL.jpg
http://photos.smugmug.com/photos/i-6...6rhL2Fc-XL.jpg
http://photos.smugmug.com/photos/i-j...jF2MLJ9-XL.jpg
There was also this small gouge in the area of what I consider the weak link of the OEM lower arm, this could be a 'stress riser' which could magnify the chances of stressed failure.
http://photos.smugmug.com/photos/i-K...KXb5Mxh-XL.jpg
http://photos.smugmug.com/photos/i-x...x4rqPD2-XL.jpg
2 hours of media blasting later I still don't have a paintable surface.
http://photos.smugmug.com/photos/i-V...V56rRwz-XL.jpg
:bang:
Vince@Meanstreets 03-21-2015 10:24 PM
Originally Posted by Sieg (Post 599563)
I see you have the much needed Greg Weld bushing spacer adapter.
Did you make one for the upper arm yet?
Sieg 03-21-2015 10:37 PM
LOL.......you don't miss much Hawkeye! :lol:
Greg Weld......Global West......similar, only much much different.
I'll concoct something for the uppers. :thumbsup:
Vince@Meanstreets 03-21-2015 11:06 PM
1 5/8 tubing with a 1" slot cut into it (for cross shaft to fit into) and fits between the arm opening.
JB400 03-21-2015 11:18 PM
Out of curiosity, what was your method for fixing your stress riser?:popcorn2:
