-   -   Norwood (https://www.lateral-g.net/forums/showthread.php?t=36443)
Sieg 03-21-2015 11:22 PM
Originally Posted by Vince@MSperfab (Post 599567)
1 5/8 tubing with a 1" slot cut into it (for cross shaft to fit into) and fits between the arm opening.
:idea: .........finally, justification to buy a mill! :lol:
SSLance 03-22-2015 04:15 AM
It's gonna feel like a new car when done!!
Or at least look like one when when you crawl under the front of it. :D
GregWeld 03-22-2015 06:42 AM
This and the brakes are going to be really nice "improvements". While we know it's only a street driver - these old grey mares ain't what they used to be.... and they need all the help they can get. I did this same kind of upgrades to one of my '69 Camaros (a real Z/28 RS SS) - along with a simple transplant of the 302 with a HO 350 crate motor - a 5 speed - and bolt on Disc brakes in the rear... and THEN I liked driving it!!
BTW -- A good powder coater would have bead blasted those before coating them - and they'd come back so beautiful you'd want to hang them on the wall as art. If you do decide to just paint them -- do yourself a favor and use POR15 -- you will have to clean out the arms where the bushings go because the stuff builds up a pretty good millage. I've found just painting them - they're beat up by the time they get re-installed. I know a good pinstripper in Oregon -- he could lay some nice Hugger Orange do dads on them for ya. LOL
GregWeld 03-22-2015 06:49 AM
Come over and get mine! I'll then 'have' to buy a new one.....
It ain't the mill that's expensive -- it's the tooling you'll need to be able to actually use it. Oh and a good mill vise - can cost half of what the mill did... you'll need 2 flute cutters for aluminum - and 4 flute for steel - in all the sizes... end mills and ball mills.... and collets for all of 'em... and an indexer... and a coolant pump and tank/recovery system... and all manor of dial indicators and set up tools... and a cabinet to keep all that stuff in.... and 220V 30 amp power... and really good lighting... and it's the size of a refrigerator... so you'll have to add on to the back of the garage... :thumbsup: :poke: :superhack: :G-Dub:
Sieg 03-22-2015 07:34 AM
Originally Posted by JB400 (Post 599568)
Out of curiosity, what was your method for fixing your stress riser?:popcorn2:
I smoothed it with a Dremel and ran a bead over it with the MIG.
I'm very interested in what the front suspension will feel under hard braking and turn-in with Delrin bushings vs old OEM rubber. As bad as the OEM rubber looked from the exterior, I pulled a couple apart and the concealed 'bearing' surfaces were actually in good shape.
They may still go to the powder coater as I have a gate frame to build that needs to be powdered coated this week.
Is a pinstripper similar to a polestripper? Or were you talking about Mitch "WingBo' Kim the pinstriper?
I'll see you on Wednesday, but only if you throw in the hedge trimmer with the deal............:action-smiley-027:
GregWeld 03-22-2015 07:47 AM
Like Motel 6 - I'll leave the light on for ya.
Doesn't mean that I'll be home now that I've gotten fair warning of your arrival date.
I like pinstripper better than pinstriper. Mitch Kim is EXACTLY who I was thinking of. He did Rudy's.
Sieg 03-22-2015 07:59 AM
Ain't happening Lancelot..............
At some point in Norwood's past, probably in his teenage years, I'm guessing he had a cross country off road trip........so here's the other hot-rodding fix I spent at least two hours on yesterday just so I could run a rod through the lower control arm pick up points to make sure they're in the ballpark.
http://photos.smugmug.com/photos/i-j...jWRNVJQ-XL.jpg
http://photos.smugmug.com/photos/i-Z...ZgtTS82-XL.jpg
After multiple pulls on the folded lip with a big Crescent wrench and cheater bar, then an incision in the stretch point I ended up with this.
http://photos.smugmug.com/photos/i-B...BTZvZgB-XL.jpg
Then this.
http://photos.smugmug.com/photos/i-D...DbTm43g-XL.jpg
http://photos.smugmug.com/photos/i-t...tZMJzkB-XL.jpg
O'l Norwood ain't going to win any beauty contests unless Stevie Wonder is judging.
SSLance 03-22-2015 09:04 AM
lol... You know, Ol Foose would have bondo'd up those hammer marks on that after straightening it back out. Jus' sayin'
And what's with all of the oil deposits? I know you don't need any corrosion protection out there. ;)
And that rod through the control arm pickup points trick, where'd you learn that from. http://www.speedinfinity.net/forums/...lt/popcorn.gif
Nice work Sieg, keep it up.
GregWeld 03-22-2015 09:08 AM
Those come from NOT running an LS motor.....
Vince@Meanstreets 03-22-2015 09:25 AM
Naw, after see your patience with the bead blaster a normal 2 hours with a die grinder and sanding disk should be good.
Mill, just like Greg says a whole lot of money is the sum of its parts.
