-   Transmission and Rear End (https://www.lateral-g.net/forums/forumdisplay.php?f=39)
-   -   rear end question (https://www.lateral-g.net/forums/showthread.php?t=11261)
race-rodz 10-04-2007 01:06 AM
if the housing is bent...it wont wobble. the tire will just be out of alignment. if the outer bearings are good, and they fit the housing tight, then the problem sounds like a bad carrier bearing. a lil slop on that end of the axle will cause a bunch of wobble on the outer end. i would immagine that you would be getting some type of gear noise if its that sloppy..... pull the 3rd member and check it out before you start spending money.
etp2563 10-07-2007 01:53 PM
that sounds like a good idea i will do that i really dont want to buy a new one but u know rebuilding the old one and saving some money wouldnt hurt im almost 99% sure that the third member could be causing that thanks for the info
chicane 10-07-2007 03:26 PM
Before you do ANYTHING.... check to make sure that the rotor will seat on the axle correctly. Mostly what you are looking for is that the rotor ID for the register fits over the axle register itself... and that there is enough of a chamfer on the ID of the register hole so that it fits over the axle register.
If all you did is add disk brakes to the rear end... I can almost guarantee that this is your issue. Since you have not changed anything else... this would make the most sense.
etp2563 10-08-2007 11:54 AM
well i did all of that when i put them on the first time i tried putting just the wheel on there and it does the samething with the just the wheel so its not the rotors
