Can you give me the specs on your Wilwood break system?
I put the 93-97 F-Body big brake kit on the front which required fabricating my own caliper brackets. 13" drilled & slotted rotors, 6 piston billet aluminum superlite calipers, PolyMatrix "E" compound pads, aluminum rotor hats, stainless braided brake lines. The rear is the Chevy 12-bolt kit. 12" drilled & slotted rotors, 4 piston Dynalite calipers, cast iron rotor hats, and integral parking brakes. Proportioning valve. The master cylinder is Wilwood's new aluminum tandem chamber with a 1.12" bore. And finally, to give it plenty of muscle, a Hydroboost system from Hydratech Braking Systems.
