would that be one of the new super cyclonic vacs...or a good ole fashioned hoover :unibrow: |
Just add a small 100shot of nitrous,Charlie. That will spool the turbo up almost instantly.
What about a pinion e-brake? It would be easier to hold still before the ratio is multiplied
Mike |
as im just learning about the elec controled trans... is it possible to program in a "trans brake" feature?
No. No trans-brake feature. But if he has more boost off the line he can calibrate the TCU to short-shift or soften the 1-2 shift to limit wheelspin. The calibration process is as easy as checking your email.
Edit: There is also a transmission controller made by a company called Powertrain Control Solutions that that can vary your transmission calibration relative to boost/ It analyzes input from both your TPS sensor and your MAP sensor to determine load. The computer "trims" your calibration when boost is present. |
| All times are GMT -7. The time now is 03:27 PM. |
