But i do have a friend with 64 vette+LS3 and he wants to keep the stock unpowered steering. And i trying to help him here |
2 Attachment(s)
Heres the bracket setup were using on one of our projects right now and places the A/C proportionaly with the alternator. This motor came from Turnkey.
Accessory Brackets
2 Attachment(s)
Here is my set up. I used stock 98 camaro brackets and made my own A/C bracket. I had to notch the frame and use a Zexell compressor because of the fitting location on the back. The sanden fittings come out in a v shape and the Zexell fittings come out parallel.
Guy |
Can you post up some pictures of the bracket you made, if you have then?
Also, can you give me some more information on your compressor? I cant find a website for them. thank you |
Look at the third pic closely, the bracket is only a 1/4" piece of flat stock with a spacer welded to it.
Oh and type in ZEXEL for a compressor search. Repeat after me " Google is my friend " |
Saden 7 brackets for LS
We machined these brackets & pulleys for a Saden 7 AC compressor for a LS2tack system.. & dressed up the pulley on OE water pump.. I am ordering a LS1 track system next week for another build here @ the shop & will compare..
http://i1015.photobucket.com/albums/...irebird062.jpg http://i1015.photobucket.com/albums/...n/P9200015.jpg |
About the search, Im still coming up with junk sites. http://www.zexel.co.jp/ Can you post up a part number? |
| All times are GMT -7. The time now is 08:20 PM. |
