T56
The 93 was the weakest of the T56 from a F-body, your's is a 94 and I'd be fine with that year and later.
Autozone carries LUK components. Ray |
I'm putting a T56 in my 442 with 3.73 gears and a 27" tire and I can shift into 6th going 65mph at 1500rpm for cruising according to the gear calculators. Just depends on if your motor will be happy at 1500rpm or not. With the existing 3.42 gear it will be 70mph @ 1500rpm. So it's definitely usable if your tire size is relatively close to that size. http://www.nastyz28.com/forum/showth...98#post1913198 |
I ended up driving in 5th a lot since it just felt wierd at that low of an RPM. BUT, i got insane gas mileage.. like 26 mph.. keep in mind that's why the .50 ratio exists, to make CAFE standards. |
| All times are GMT -7. The time now is 07:32 PM. |
