| GregWeld |
11-28-2009 09:18 AM |
Originally Posted by jcal87
(Post 250859)
Yeah i think thats what i am going to go with do you have yours hooked up to a bottle? and what size wire do you use?
Use gas with your MIG... it's a mix argon and co2... the flux cored wires are for farm truck use.
Thin sheet metal - .023 wire works real well. If you're stitch welding (a series of small tacks) snip your stick out at an angle (one snip at like a 45) to form a fine point EACH weld. This will help a "newbie" get a clean weld. Doing this makes the wire need less voltage to start the weld... and will help you with burn thru. Once you get better you can get by without this step. Get yourself a pair of "welpers" = it's a plier that is good for MIG welding use. They're tapered square nose - to clean out the hood slag - and have cutters built in.
Also -- CLEAN bare metal - both sides of the weld area... will making welding easier and the quality of the welding much better. Make a good GROUND for the ground clamp! Skip this and you'll have issues. Good "fit up" is critical to good welding. Take your time and make your pieces fit! Just the right gap makes a good weld and makes things EASY - start getting sloppy and you have to be a much better welder to close em up and make a good weld too...
:cheers: :woot:
