Looking online I found those style delphi crimpers with a "normal" (standard length?) handle and ones with a "longer handle". For those who have used these, is there any difference between the two when using them?
I'd buy the shorter for that time when you need to crimp in a tight spot. If you need the long handle you better go enroll at your local health club. :unibrow:
Cool thread. I plan on repinning my own harness so I need a good set of crimpers. These do Metripack too? I have not had to mess with those yet but of course I will.
Todd has Kelli do all his heavy lifting.... |
Here's the "description" of this particular model: This is the Genuine Delphi Crimper, 12014254. Compound leverage ratchet mechanism reduces operator fatigue, ensures crimp completion and provides exactly the same crimp time after time. Crimps Weather Pack terminal and seal in one cycle. Features two double cavities, an orientation block and a ratchet mechanism to ensure that each crimp cycle is completed. Factory calibrated to be used only with Weather Pack terminals and seals. Wire range 20-14. It's the "ORIENTATION BLOCK" that is the big difference for me... |
This is where I bought mine --- they offer MANY that do Metri and Weatherpack... all prices and styles.
http://www.bmotorsports.com/shop/ind...th/111_112_170 |
Weather pack connectors
Where is the best place to buy the actual connectors? Do you order them individually or a whole kit? I've got the American Autowire kit for my Camaro, do you guys recommend replacing all of the ends or just the ones exposed to the elements?
I bought a weatherpack kit from Casper electronics. I'd recommend them on exterior connections like fans, fuel pump, igntion box, distributor, trinary switch. I'd also recommend using dielectric grease in all your standard connections and ground surfaces.
Amazon has suppliers for kits -- if you just want a "starter" kit... $60 http://www.amazon.com/gp/product/B00...G6JWQ4J76ZPJEF OR --- BETTER KIT HERE.... $129 http://www.diyautotune.com/catalog/7...kit-p-380.html |
You might want to take a look here too : http://www.digikey.com
| All times are GMT -7. The time now is 12:27 AM. |
