-   LSX Conversions (https://www.lateral-g.net/forums/forumdisplay.php?f=70)
-   -   Pics of Dynatech LS first gen camaro headers as requested (https://www.lateral-g.net/forums/showthread.php?t=29744)
70rs 06-22-2011 02:08 PM
Originally Posted by 505camaro69 (Post 355414)
Can you repost with the pictures available?
:ttiwop:
X2
I would like to see these too.
Have you installed these in any second gen camaros yet?
almcbri 06-22-2011 03:58 PM
There are pics of mine on my photobucket. They will not fit brp mounts and clear the box. I Havent tried them on my 68 with s&p plates.
1HTBRRD 07-22-2011 09:38 AM
Wondering what part # you used for the MSD wires? I was looking through Summit and they all seemed to have the straight spark plug boot which would hit the #5 and #7 primary tubes on the driver's side.
On a side note, I am running these headers on a 5.3 in a stock subframe with stock power steering and stock upper control arms if anyone wants to see photos of fitment.
-John
almcbri 07-23-2011 07:22 PM
-John
I wold like to see them! What motor mounts are you using and are they the stock location motor mounts? I hope mine clear, but I am still a month away from getting the motor back in.
tango68ss 07-25-2011 12:31 PM
Here's my '68 vert with DynaTech LSx headers. I love 'em!!
http://www.screaminperformance.net/g...s/IMG_6188.JPGhttp://www.screaminperformance.net/g...s/IMG_6190.JPGhttp://www.screaminperformance.net/g...s/IMG_6193.JPGhttp://www.screaminperformance.net/g...s/IMG_6194.JPGhttp://www.screaminperformance.net/g...s/IMG_6196.JPG
Take a look at my build link (pcis #416-430) for better/ more detailed pics of the header fitment.
TC
1HTBRRD 07-27-2011 08:38 PM
4 Attachment(s)
I used the transadapt plates and motor mounts (http://www.summitracing.com/parts/TRD-4595/).
The pictures don't do the headers justice because my power steering lines are in the way. The headers fit great and they were easy to retrofit to my old big block exhaust.
Attachment 31316
Attachment 31317
Attachment 31318
Attachment 31319
There is about 1/2 an inch between the driver's side upper comtrol arm and the primary tube although it's hard to tell from the photos.
almcbri 08-09-2011 07:06 PM
They fit good! I need to trim a small piece of the SBC mounts. I am using the carshop mounts. http://i14.photobucket.com/albums/a3...i/7d9a6f2b.jpg
http://i14.photobucket.com/albums/a3...i/2aa55a60.jpg
http://i14.photobucket.com/albums/a3...i/cdc5227e.jpg
http://i14.photobucket.com/albums/a3...i/f5453559.jpg
1HTBRRD 08-10-2011 03:35 PM
Originally Posted by tango68ss (Post 361874)
I ended up using the msd multi angle plug wires with my headers. Just like I thought, the #5 and #7 spark wires are up against the primary tubes. I was able to bend the msd multi angle plug ends and then zip tie them up so they would not touch...but I recommend to anyone else using these headers to get the right angle plugs that will give you more clearance. The driver's side pic above clearly shows how there is not much real estate around the #5 and #7 spark plugs.
boostin05blacks 09-01-2011 08:46 AM
Im looking to get a set of these and have s&p plates. Can anyone confirm if they will or will not work before I pull the trigger? Thanks Steven:thumbsup:
Update:01/27/12
So i pulled the trigger and bought these. As far as price goes they cannot be beat..they fit very well with my s&p mounts. Clear the steering box with ease the only issue I see if I have to ground a little material off of my drivers engine mount but that no big deal..here are some pictures.
http://i18.photobucket.com/albums/b1...s/24883e39.jpg
http://i18.photobucket.com/albums/b1...s/47c6fad9.jpg
http://i18.photobucket.com/albums/b1...s/00b96ffb.jpg
http://i18.photobucket.com/albums/b1...s/b1631b1b.jpg
http://i18.photobucket.com/albums/b1...s/ae05488f.jpg
http://i18.photobucket.com/albums/b1...s/90385641.jpg
http://i18.photobucket.com/albums/b1...s/6544518b.jpg
http://i18.photobucket.com/albums/b1...s/4ae69e09.jpg
KSBRKTRACER 04-11-2013 09:16 AM
Update:01/27/12
I know this is an old thread , but I have a couple of questions ...... Is there header made that has better ground clearance...? These appear to hang down a little bit too much for my liking. Does anyone have any suggestions : I am doing a stock subframe , stock Power steering gear box , and it has factory air conditioning in a 69 . I am going to use a 6.0 and LS-3 heads is my plans.
