-   -   18" NewGen Splitters with Nitto Tires (https://www.lateral-g.net/forums/showthread.php?t=33752)
tempered 10-02-2011 08:52 AM
wheels
i am interested and would like to find out if they would fit my 66 pontiac tempest
tempered 10-05-2011 06:23 AM
wheels
can anybody verify that these will fit my car
wmhjr 10-05-2011 10:08 AM
I'm relatively confident that the front will fit. I'm not so sure about the rear. To run 275s, I had to modify my rear wheel houses and fender lip. I have very little clearance even having done that with my '66. At this point I have the maximum available room without notching the frame or widening the rear fenders.
tempered 10-06-2011 06:42 PM
wheels
thanks for you're reply i have the longer 12 bolt chevy rear in my car
wmhjr 10-07-2011 04:52 AM
That's not your problem. The problem is simply the amount of space in the rear wheel wells. Take off a rear wheel, and start measuring INSIDE the wheel houses. Look above the inside wheel well lip. I removed most of heat you see, and still 275s on 10" wheels (which result in a narrower cross section than the same tire on a 9" wheel) have very little clearance. Track width, ie the total width of your 12 bolt, only affects backspace.
