-   LSX Conversions (https://www.lateral-g.net/forums/forumdisplay.php?f=70)
-   -   Some LS9/T56 HELP please (https://www.lateral-g.net/forums/showthread.php?t=37692)
MattG 02-04-2013 06:21 AM
Same thing happened to me and it was the pilot bearing..use the old smaller size and you'll be fine!
chr2002ca 02-04-2013 11:11 AM
You should check over in the Project Updates section in the "427ci LS2 sleeved, dry sump" build thread. Dale had to by a spacer plate from D&D that goes in between the bellhousing and magnum transmission in order to move the transmission back about 7/8". Might apply to your situation also.
Bowtieracing 02-13-2013 11:06 AM
I had excatly the same with my LS7 and D&D T56. Problem was big corvette style pilot bearing.
If you have this
http://i4.photobucket.com/albums/y14...i/86eee8bb.jpg
You need to take it out and use this one wich fit 3/4" deeper.
http://www.speedengineeringlsx.com/g...aring-14061685
