-   -   Gun Drilling (https://www.lateral-g.net/forums/showthread.php?t=39189)
Bryce 11-20-2012 11:39 AM
Originally Posted by wellis77 (Post 447373)
When you say to machine it within .020" first, then heat treat, are you suggesting to cut it over or under the 24" length I need. The only other machining then is drilling and tapping. The diameter of the drilled hole is not as important as making sure the threads are dead on. So, cut to length (over by .020"?), heat treat to H-900, throw it on a lathe and turn it to 24", then have the hole drilled and tapped? Thanks Bryce.
I was suggesting all critical dimensions be around .020" over, OD and ID. Then heat treated (things move around at 900F for 2 hours) then final machined. But that could be a logistical nightmare. I have a machine shop and a furnace lab about 100 feet away from my desk, haha.
I would suggest going to one supplier to have them make the part. That way they own all operations and processes even if they sub out work they still have to deliver a per print part. Let me know if you want some help with drawings.
I suggested moore performance because they make input shafts for nitro drag cars. He must outsource his heat treating...
wellis77 11-20-2012 11:44 AM
Thanks for clarifying Bryce. I'm waiting on a phone call back from Moore yet. Coordinating everything myself would be a logistical nightmare for sure. I've drawn it up so I should be all good there. Thanks though.
Spiffav8 11-21-2012 07:56 AM
Originally Posted by wellis77 (Post 447369)
I don't know who Britney is Curtis, but her price is very good; a ways away or not that is probably where I'll be going.
They build some nice equipment too...
Yeah they build some crazy nice stuff there. Great people to boot. Glad I was able to make the connection for you.
Oh and Britney's a hot little number. :yes:
