-   Shop & Equipment (https://www.lateral-g.net/forums/forumdisplay.php?f=56)
-   -   New Welding Table (https://www.lateral-g.net/forums/showthread.php?t=45647)
Revved 03-24-2014 08:35 PM
Awesome!!! Great idea with the slots!! I may take you up on that file when I get caught up on other projects... I've been thinking of building one myself.
DTM Racing 03-25-2014 06:07 AM
I like it!
If I may...You may want to add more filler next time to your TIG welds, as they look a bit too concaved, probably from you beveling the edged prior to welding. When the bead shrinks back like that it is thinner than the base material and creates a weak spot. When welding a joint like that, the bead should be as thick as the base material.
rwhite692 03-31-2014 08:11 PM
Thanks DTM, Those welds are in compression so didn't bother to put a big bead on them.
