I did run into this. Corrected a few of my issues.
Ridge on the mount hitting
Excellent! I will give it a try. Thank you
Im going to go with your speed tech "kit" when i go with ls........
A couple questions Blake, first I see that you have a header that works with the tru-turn, will that header work with a mechanical clutch linkage? also wondering if you make a pan without the remote filter? I personally like buying all my parts from one vendor, that way everything is designed to play nice with each other and all of the headaches have already been worked out.......... just my $.02 |
we do not make a pan with out the remote filter. if you want to buy everything from one supplier we can sell the Autokraft pan as well. |
| All times are GMT -7. The time now is 01:05 AM. |
