-   -   Gas pedal suggestions (https://www.lateral-g.net/forums/showthread.php?t=5174)
bigtyme1 05-01-2008 06:54 PM
Originally Posted by camcojb (Post 52393)
I just wish Lokar would modify their firewall mount so you don't have to egg-shape the holes to bolt it on. They're off just enough, and it would be a simple fix.
Hey Jody, what's you fix for this? just ran into the same problem tonight. Got a small air gap 1/8 inch.
Payton King 05-02-2008 06:37 AM
Wow this is an old post
If you firewall is not painted you can add some material. If it is painted like mine was. I bolted it in and used silicone to seal the hole and around the mount. Then covered on the inside with sound deadener.
