-   -   New 13" Wilwood 6 piston C6 Brakes (https://www.lateral-g.net/forums/showthread.php?t=52414)
tubbed69 03-12-2016 09:12 AM
Originally Posted by Sheck44 (Post 632242)
Ya I have the same kit and I can space different rotors from 12.5s up to almost 15" with adding spacers
Cheers
Steve
Thanks Steve that's what I will do
tubbed69 03-12-2016 09:16 AM
Originally Posted by MillerBuilt (Post 632250)
I just checked my "bone pile". I did not have any of the Wilwood spacers in that size. Again, no real need for the actual "Wilwood spacers", as a stack of washers with the correct i.d. & o.d. is just as effective.
Note: I was incorrect on specifying the use of 3/8" AN washers to do this. I was going off memory, and the AN washers are used along with the 12 point nut to fasten down the caliper. The washers you will need will have the 3/8" i.d. and an o.d. large enough to max out the "seating bore" in the caliper to better help stabilize the caliper.
Glad this info helped. From my own experience in past, it was quickly realized that thre is ZERO resale value on aftermarket brake kits.
Good luck!
Jay
Thanks Jay,that's what I will do.
tubbed69 03-12-2016 09:17 AM
Just rotors will be for sale now.$200
tubbed69 03-15-2016 05:28 PM
Sold
