did a search and this is a thread on the console setup https://lateral-g.net/forums/show...t=42957&page=2 |
It would help if you said which pcm that you have? I am running a Gen III "411" pcm, which is the largest of them Using a GM mounting bracket, slightly modified and have the pcm mounted horizontally on top of trans tunnel @ firewall ( GM#15995679 mount) it sits just under the custom 4 gauge pod that is in my console The engine harness relay bank and fuse panel are mounted to firewall ( laid out/ mocked up with Vintage Air unit & hoses prior & welded mounting studs prior to firewall finishing), just above accelerator pedal for ease of servicing/ access the OBD II port is just under dash, adjacent to steering column Using the glove box insert from Vintage Air kit I will do the same on Curtis's car when it comes to my shop in next day or two Hope this helps Jeff |
Thanks Jeff, I'll definitely be watch the progress on that car! Sorry it's an E67
| All times are GMT -7. The time now is 12:01 AM. |
