-   Interior and Electrical (https://www.lateral-g.net/forums/forumdisplay.php?f=40)
-   -   What's goin on with ISIS (https://www.lateral-g.net/forums/showthread.php?t=33833)
ccracin 10-10-2011 05:30 AM
Originally Posted by jharris (Post 373196)
Hey Guys,
Here are another few thoughts.
We were originally part of Littelfuse. I spent about 17 years there and led the development of ISIS. In early 2009, I led a team of investors to break of business off to manage it independently. Littelfuse it still a critical part of our business. They are part of our supply chain and we work together on specific market opportunities.
ISIS was originally developed for the off-highway, agriculture and military markets. We stumbled into the restoration, racing and performance markets literally by accident. The exact same hardware that has been powering the One Lap Camaro since day one, is used in busses, RV's, limousines, military trucks and command vehicles. Here's a good example.
This is one of our customers that builds high-end recreational vehicles. Their typical install has 1 MASTERCELL and 6 POWERCELLS. Check out the video at about the 1:15 point. You will see the front part of their install in the coach.
https://www.youtube.com/watch?v=AvU1v...geDecA&index=5
Littelfuse is the industry leader in automotive circuit protection. As such, our cells are filled with components to protect the system and the users from short circuits, resistive overloads, electrostatic discharges, load dumps, EMI and other nasty things that can happen in the automotive environment. The system was tested and qualified to General Motors' 3172 underhood specification. This battery of tests covers includes things like mechanical shock, vibration, thermal shocks, heat soaks, cold soaks, chemical exposure, salt-spray and salt-fog, immersion testing and electrical overstress.
That being said, we have had failures in field. Both James and John have examples of this. In both of their cars, they had issues because of the circuit protection components that exist in the system. In John's case, there is a fuse on the MASTERCELL that protects the power feed in the CAN cable. In James' case, a diode that is intended to protect the processor from high-voltage did its job.
The system was originally designed of commercial applications, which have pretty specific convetions on how to wire vehicles. Since most of these applications are pretty regulated, the circuit protection schemes were tailored tightly.
We have learned a lot about how guys have been applying the system in our aftermarket applications over the past few years and we have adjusted the levels of circuit protection to the overall system in all of the systems that we are shipping now. For example, the simple change of a fuse rating on the MASTERCELL from 0.375 amps to 0.500 amps eliminates what John Parsons saw in his car.
I hope that this gives you more detail.
Jay
Jay,
Thanks very much for posting and showing this community the type of service you provide. I have a question with regard to your last points about improvements in circuit protection. I have a system that I got as part of the group buy. Would my units have this revised circuit protection? If not, can I get it. Thanks very much. Keep up the good work. We should be getting close to laying the system out shortly. I am sure I will be in contact for some help! :thumbsup:
jharris 10-10-2011 03:02 PM
Fuses...
Hey Chad,
You have the diode changes but I think that you may have the smaller fuse on the CAN power feed.
Give us a call at (847) 232-1991 and we can arrange to send you the larger one.
Jay
ccracin 10-10-2011 04:11 PM
Thanks Jay. I have some other things I want to discuss as well. Hope all is well. Talk to yah soon.:thumbsup:
jeff71 10-13-2011 09:01 PM
Check out Eastbaymusclecars.com they did a 70 Chevelle with the ISIS system.
Z10ROD 07-27-2012 02:50 PM
my head is hurting ( i am in process of my first isis system install):_paranoid
canrc 07-27-2012 05:15 PM
I just finished my install -- some of the best customer service and support in the industry! The hardest part is mounting the cells after that the system is awesome!
FETorino 07-27-2012 11:17 PM
I'm glad to hear :D I have an ISIS sitting in a box waiting to go in my project.
Z10ROD 08-06-2012 03:19 PM
doing better now or understanding a little more I should say just a different train of thought. I got the cells mounted and kinda mapped out and no haven't been working on since my last post more thinking than anything
key fob
push button start
LS3 /4L60E
Vintage air / electric fans ( trinary switch)
have done a bunch of AAW installs and know how to keep them clean
Z10ROD 08-09-2012 01:48 PM
http://i1247.photobucket.com/albums/...onepics945.jpg
http://i1247.photobucket.com/albums/...onepics944.jpg
GregWeld 08-09-2012 01:54 PM
I wish someone would explain to me what savings in labor etc the ISIS system saves?
Your's looks great so far!
Z10ROD 08-09-2012 03:03 PM
I am trying to teach myself how to upload pic's I'v gotten alot further
and have more pic's there is no labor savings just flexability with system.
and thanks
Z10ROD 08-09-2012 03:16 PM
http://i1247.photobucket.com/albums/...onepics943.jpg
http://i1247.photobucket.com/albums/...onepics942.jpg
Z10ROD 08-10-2012 12:50 PM
note to J HORN WIRE- LEFT TURN SIGNAL- RT TURN SIGNAL THEY NEED TO BE LABLED BETTER ? I'm old and blind couldn't u use letters or numbers
red with blue or blue with red ???????
Z10ROD 09-29-2012 03:56 PM
this system is for someone who has never wired a car.
Z10ROD 10-31-2012 06:11 PM
unless you plan on using an Ipad to control your car ( everything ) this is a terrible choice and is way more expensive than AAW. like 3 times as much work. like vintage air stands alone so does speartech engine and trans controls this is rethinking at the beginning maybe after R&D 3 years from now but not at this time. just my opinion I'm intitled to that right this is not my first build by far.its just not worth it right now maybe later.:yes:
