-   -   Project 'Overtime': Pro-Touring 68 Acadian (Nova) with L92 swap (https://www.lateral-g.net/forums/showthread.php?t=14349)
waynieZ 01-08-2010 04:10 PM
Nice update . How about some rivnuts like the ones they hold the console in the Camaro's.
scherp69 01-08-2010 04:11 PM
Originally Posted by Vegas69 (Post 259945)
Nice updates....I think you have the shifter on backwards for our application. Meaning your reach will be affected. Mine has the shifter in the back hole. Reach is perfect, of course it's a camaro.
Just had someone else comment about the shifter location. He also has a 68 Nova and has it in the stock location (the way it was originally). He mentioned that he tried it this way and it didn't feel as good so I may end up changing it back. Good thing I made the hole big enough to access it.
Originally Posted by BBC71Nova (Post 259963)
Coming right along.
The removable tunnel discussion came up a lot on the FFR related forums because of the same issue. There is a rivnut type deal you might want to look into. If I remember correctly it is like a nut that you rivet into the panel. Using nuts/bolts would be better than plain rivits IMHO but getting to the nuts is a pain after the fact. The riv nut makes that blind nut not such a big deal.
John
Thanks John. I'll look into that.
scherp69 01-08-2010 04:13 PM
Thanks Wayne. I was just looking at www.rivetnuts.com I think you guys are right...those look like they will do the job nicely. Thanks for the heads up on those.
GregWeld 01-08-2010 04:26 PM
Rivnuts are simple and effective... easy to use too...
Neat update -- glad something fired you up and got you out there bangin' up your knuckles!
LOL
98ssnova 01-09-2010 12:34 PM
We use rivnuts on B-1's just be carefuly and amke sure you "lube" the thread graphite works best IMO:thumbsup:
syborg tt 02-09-2010 08:36 AM
Awesome Project - just read the entire thread
waynieZ 02-09-2010 08:20 PM
Anything New? I need my fix.
scherp69 02-10-2010 12:07 PM
Thanks Marty.
Here's the update Wayne.
I finally had a couple hours this morning to go play in the shop. My step daughter started a new school this semester and hasn't made any new friends yet so I have been taking her out for lunch on my days off. It's amazing how that interferes with my shop time :devil:
I borrowed this idea from Billy's (72novadriver) car. http://i326.photobucket.com/albums/k.../gascapweb.jpg I love the way it look so thought I would do the same thing to mine. Billy made his insert, but I cheated. I found someone who was willing to cut out the filler cap portion of a tail panel from a 67 Camaro.
Bought a filler cap from Chassis Works. Beautiful piece. Not cheap though. I know there are cheaper ones out there, but I decided to go with this one.
http://i222.photobucket.com/albums/d...9/P1000270.jpg
Panel from the Camaro
http://i222.photobucket.com/albums/d...9/P1000269.jpg
Cut it down to a better size
http://i222.photobucket.com/albums/d...9/P1000275.jpg
There's a bit of a contour to these, so I had to finesse it a bit
http://i222.photobucket.com/albums/d...9/P1000272.jpg
Had to clean up the area where I was going to weld it into place
http://i222.photobucket.com/albums/d...9/P1000274.jpg
I had to find centre and start cutting
http://i222.photobucket.com/albums/d...9/P1000276.jpg
Temporarily in place
http://i222.photobucket.com/albums/d...9/P1000278.jpg
Welded into place and the filler cap is in place for a test fit. It's missing the gasket in behind so will stick out a little farther. I might make a thicker gasket so it is a little more flush with the tail panel.
http://i222.photobucket.com/albums/d...9/P1000281.jpg
http://i222.photobucket.com/albums/d...9/P1000282.jpg
Now I have to modify the trunk to fit the filler neck.
http://i222.photobucket.com/albums/d...9/P1000283.jpg
Hopefully I'll get out to the shop again in the morning and finish up the welding and start fitting the filler neck. What do you guys think??
67rstbkt 02-10-2010 02:20 PM
That looks awesome so far. I robbed your idea and got a piece from another member on here willing to do the same thing for me :thumbsup: . I just got it yesterday. Thanks for the idea, update, and the pictures :cheers:
waynieZ 02-10-2010 09:52 PM
It looks great, and nice idea to use the piece of tail panel.
