Lokar 6" automatic transmission billet shifter with their optional LED billet bezel and Naugahyde shifter boot
Ok thanks ill look into it
Welcome:cheers:
How's that rotisserie working out?making any progress on the bottom side?:gitrdun:
Rotisserie is working great! They sure make life easier.
I've just about finished all the welding I needed to get finished up. I'm in the process of finalizing the audio system install. I'm welding in some plates to mount some speakers in the kick areas and then will be done with all the welding. I'm going to go back and work a little more on the Airbar fitment. When I pulled my car out of the garage a few months ago, I didn't like how the rearend was sitting under the car, so I'm making sure the cradle was installed properly. Unfortunately, I'll have to mockup the rear suspension again. I need to get all this done before I put the finish paint underneath. I'm also trying to work out the fuel and brake line routing. I replaced the floor pans and do not remember where the original clips were located. Also, I've installed DSE subframe connectors and trying to figure out how to cross the lines over the connectors. I've had pinkeye all week, so I haven't managed to do much of anything on the car. It's nearly healed up, so its bout time to get back at it. Thanks for asking:) Been driving your car yet? |
2 Attachment(s)
What did everyone do with DSE subframe connectors when routing the fuel and brake lines? How did you cross over the connector? Did you fab a channel into the connector or did you just route them over the it?
Also, my Ridetech Airbar on one side has a mm of touching at the back of the floor pan and the other side is about 1/8" away from the back of the floor pan. This is where the forward tube crosses over from frame rail to frame rail. Will this be sufficient or should I address this? |
well i had the same issue but because i'm mounting my master cylinder inside the dash i decided to run my brake line inside the car....i just mocked it up so far but will post some pics shortly... the way you have it mocked up looks fine .....keep at progress is looking good
The project is progressing nicely.I'm glad you desided to finish it.:thumbsup: :gitrdun:
Thanks guys. I'm hanging in there
| All times are GMT -7. The time now is 01:09 PM. |
