-   -   ASP "DC/Kalis" 69 camaro build....... (https://www.lateral-g.net/forums/showthread.php?t=18578)
skatinjay27 01-11-2010 02:08 PM
Originally Posted by phillym5 (Post 260700)
I assumed i was using the same ones.... you see an issue with that??
By the way... the rear axle stopped leaking on its own............
no issue just the AFX spindles are leaps and bound ahead of using stock ones with the G-mod
Vegas69 01-11-2010 02:26 PM
No problem except you're basically making a aesthetic change. Did you already have the Gulstrand mod on your stock sub?
monza 01-11-2010 02:53 PM
I guess that also answers how I could not figure how the brakes would work?
skatinjay27 01-11-2010 10:27 PM
if speedtech is sending you a fully done frame then Im assuming you'll be getting the AFX spindles too and those need vette based brake setups. i would think some of your brake parts would interchange though.
on a off topic note: i watched the "text yo self" with you like a month ago...damn that was funny CIRCLE JERK hahaha...
phillym5 01-11-2010 10:35 PM
No... i did not do the mod.
phillym5 01-11-2010 10:44 PM
I am receiving the complete frame. If it does need Z06 brakes... i have access to a few sets.... so thats a good thing. For some reason i assumed the current Willwoods i have would have just swapped over.
skatinjay27 01-11-2010 11:13 PM
keep in mind you dont have to run z06 brakes if you dont want to, you just need the brackets and rotor hats that were designed for c5 or c6 uprights and you should be able to keep you willwoods.
phillym5 01-12-2010 10:27 PM
I just remembered... i have the Fatman 2inch drop spindles.
phillym5 04-06-2010 10:30 PM
7 Attachment(s)
I installed the Speedtech subframe..
What a HUGE improvement over stock. There is no rubbing issues at all. Here are a couple pics of the install. It took about 3 days to do. My car has a twin turbo set up... and the only 2 things that had to change was the exhaust downpipe on the drivers side... and i had to notch a section for an intercooler pipe. Other than that.. it was extremely painless.
98ssnova 04-06-2010 10:50 PM
Car looks good I have been thinking about getting this sub myself but dont know if it in the cards.
