Excellent craftsmanship!!!
Thanks for the kind comments guys. In the end it's not really craftsmanship but mostly persistence to learn new things that keeps me going. I do wish I was faster though!
I am really enjoying your build, keep up the great work! From what I can see you are using 80 grit to prep metal surfaces(with a combination of DA and die grinder), is this correct?
Also, avoid touching metal with bare hands. Gloves keep your skin moisture from starting new rust spots, but I forget that one all the time! Hope that helps. Scott https://i.imgur.com/Vf1nrUUl.jpg |
Beautiful evening in the garage for brake line work. Won't be able to work with the door open much longer !
https://i.imgur.com/Z6DbkIXl.jpg |
Vent lines and differential brake lines
I made a little more progress on things. I bought some Earls vapor guard hose and fittings for the fuel tank and differential vent and got those all plumbed.
https://i.imgur.com/Rw69jhMm.jpg https://i.imgur.com/w0ma9Mel.jpg I ordered some 3/16 and 1/4 inch brake line from Classic Tube. I also ordered a really nice tubing straightener from Inline Tube. It looked heavy duty in the photos and I liked the gear drive. It was huge when it finally arrived, sort of overkill for 3/16 brake tubing. My friend and coworker Dustin also loaned me his hydraulic tubing flare tool – nice! https://i.imgur.com/U6ykbXhl.jpg https://i.imgur.com/Z2cznwvl.jpg I jumped in and started making patterns with aluminum welding rod. You can see how different the tubes are from stock to clear the DSE 4-link brackets. It took a little while to figure everything out but the results were good. https://i.imgur.com/CXnrhfGl.jpg I made these little brackets for the brake hoses from some stainless angle. https://i.imgur.com/zTALg6Fl.jpg https://i.imgur.com/5fQgGWBl.jpg One trick I stumbled on when a magnet accidently stuck to a bracket, use magnets to keep small parts from dropping to the bottom of your glass beading cabinet. Not sure why I didn’t think of it before! https://i.imgur.com/0jQXndql.jpg The differential brake lines are almost complete. I ordered some little stainless clamps to secure them in a couple more spots. I also need to find a center differential brake hose. Here are some images of the installation. https://i.imgur.com/pfuAgzFl.jpg https://i.imgur.com/FmiwD7al.jpg https://i.imgur.com/B8T8s0xl.jpg I am going to route the brake line through the subframe connector like I did on the other side with the fuel line. I got started on the channel and picked up some scrap stainless to make the little cover. https://i.imgur.com/dFwudxVl.jpg https://i.imgur.com/frumTGvl.jpg https://i.imgur.com/TJ9BwuUl.jpg https://i.imgur.com/Ijialoul.jpg I ordered a proportioning valve bracket so I can get that mounted and this week will finish the subframe cover and start on the rest of the brake lines. |
Scott, that is just awesome. I finally mounted the ECM bracket I made from your template. Thanks again!!!
Hey that's great I am glad it worked out for you. Hoping to get into wiring mine later this year!
Looking good! Nice tools and you did a nice job on the lines.
| All times are GMT -7. The time now is 11:29 PM. |
