-   -   Twisting studs on the street?? (https://www.lateral-g.net/forums/showthread.php?t=26240)
phillym5 04-13-2010 01:21 PM
Originally Posted by deuce_454 (Post 281702)
the thing is, in second gear your not running 750tq to the ground.... assuming your 2.nd gear ratio is arround 2.. and your are a running 3.73 rear your tourqur to the ground is 750x2x3.73=5595 foot pounds of tourque.. !!! and over 6000 with a 4.11 !
if you have grease or oil on the axle flange you will bend the studs... it needs to be dry and the bolts torqued well a grade 8 - 1/2 inch bolt should be in the 110+ tourque range
I did have an axle seal leak for a minute........ :mad: and my gears are 3.55
CamaroAJ 04-13-2010 01:30 PM
Originally Posted by Vegas69 (Post 281696)
I've never heard of that much torque. I only torque mine to 85.
i know, tirerack.com says that too. GM specs are 100 ft lbs on cars (12mm studs) and 140 ft. lbs on the truck (14mm studs)
