Some things really don't need to be over complicated. That's how some get stuck in perpetual project mode. Ya know? ;) My 'junk' seems to be starting just fine with my so rigged terminal end. If you want to compare finished builds, I guess we can go there... But we should take that to PM's. Okay? :thumbsup: |
Mark -- lighten up...
I have some finished builds -- But I don't think we need to compare. :cheers: |
I think a guy should do whatever he can on his car to get the job done. There are so many "right and wrong" ways of doing things that its not for me to tell a guy if he is right or wrong. Just not my place. I think its good to get alot of opinions here. That way the guy doing the work can decide what is within his capabilities. And my BFH gets used often around here :thumbsup: JR http://img.photobucket.com/albums/v3...SM/hammer1.jpg http://img.photobucket.com/albums/v3...SM/hammer3.jpg |
http://cgi.ebay.com/3M-Heat-Shrink-W...item3c9da423bd |
Those are the only butt connectors I use... heat shrink and glued. I get them at my local electronics store in packs of 50 or 100 for about 1/3 what West Marine charges...
3M are the best - avoid the chinese versions. |
Inexpensive Battery Crimping Tool
The attached link has an inexpensive battery crimping tool that you can use in a bench vice. It also lists complete cable kits and a side post build-a-battery kit. I do recommend solder in addition to a good crimp.
http://www.americanautowire.com/cata...ble&Access.pdf Tim |
I'll bet you get that soldering question a lot huh? I know I do. It's always a 'debate'. I solder my big lug battery stuff - but nothing else. The problem comes with soldering - IMHO - is the person doing the work.... if they overheat the copper it gets brittle. So far.. I've seen very few people that can solder correctly. It's like welding - yeah they can weld. Which means they can get two pieces of metal to stick together... but they really can't WELD... as in - get it to stay square - flat - have penetration - and pass a bend test.... :rofl: |
| All times are GMT -7. The time now is 12:31 AM. |
