-   -   Optima battery is dead again (https://www.lateral-g.net/forums/showthread.php?t=29399)
Northeast Rod Run 11-14-2010 09:17 PM
Originally Posted by Van B (Post 316540)
There you go, factory support. If the origninal poster is not aware, Cam works for Optima. Hope you get to the bottom of your issue.
First off I was not aware that Cam worked for Optima. I actually posted this hoping that someone from Optima might chime in on here, because I knew there would be no other type of support on a weekend, so thanks for that. Also, I haven't done anything to the car that would affect my charging system, so unless there became a draw as soon as I changed to the Yellow Top, then I don't see a problem there (not saying it isn't possible but most unlikely).
Also thank you to everyone else for the help and advice. I just haven't gotten on here until now because it's been along day of football, and just now my hometown Pats managed to pull out an impressive win it Pitt!
I have read about them not taking any charge at all once they got below a certain voltage, and how to piggy back them to another battery if that happens, or buy a special charger for this type of battery
Anyway here's where I stand right now. I've had it on a trickle charger set to 1 amp all day and the battery seems to be taking the charge, because it's back up to almost 12 volts. I'll go over night with it and see how it is in the morning. If the car does start tomorrow, weather permitting, I'll take the car for a final beat run for the year and then put it away on the trickle charger until spring.
Northeast Rod Run 11-14-2010 09:23 PM
Originally Posted by SLO_Z28 (Post 316523)
Also, why do you have a yellow top? You shouldn't need one.
There were two reasons why I originally bought.
1.) I used to have the car in a garage with no power in it so I wanted a battery that could sit for an extended period (Optima claims up to 12 months with this battery). I would leave it disconnected back then.
2.) Maybe not a good reason to spend the money, but I wanted a clean and decent styled battery to match the rest of my car. Hey, I'm sure I'm not the only one on here that's done that
Northeast Rod Run 11-15-2010 08:27 AM
Well, just got back from fueling up, treating the gas, giving the car it's last cleaning of the year, putting it on the trickle charger, and covering it up.
The trickle charger worked it's magic overnight and the car started fine this morning.
Later today I'll go to my insurance company and drop all my coverages down to the minimums, because the car will pretty much sit in the garage until the spring.
Next weekend I'll probably do the same thing to the Camaro.
tones2SS 11-15-2010 10:03 AM
Sorry about your battery problem TJ.
I disconnect my battery to my Camaro and just leave it like so. I fire up the car like every other week and haven't had a problem by doing this. Good luck.:thumbsup:
(It is an AC DELCO battery, just to keep the car in stock form.)
onevoice 11-15-2010 11:57 AM
Whoever designed the marketing for these batteries should be in the in the advertising Hall of Fame. They are more expensive, have special care needs, and plenty of auto forums are full of stories about dismal reliability. Yet still people buy them. But ooooh, they work upside down. I don't know about you, but my cars stay upright.
I have half a dozen cars that are driven very infrequently, they all have regular batteries. No disconnecting cables or extra charging for them. Get in, turn the key and go. I haven't had a battery last less than the warranty period in 25 years, and several have gone 8-12 years.
Quit buying the hype.
rwhite692 11-15-2010 12:13 PM
Originally Posted by Steve68 (Post 316471)
....you have to hook up the dead battery in series with a good battery and then start charging them together...
You mean parallel.
GregWeld 11-15-2010 12:21 PM
Originally Posted by rwhite692 (Post 316622)
You mean parallel.
Yeah --- you're right Rob and there's a big difference between parallel and series!
Series would give you 24V on the output side.... parallel keeps it at 12V.
Paladin 11-15-2010 01:56 PM
optima red top
went through two of them in 4 years. can't hold a charge. ditched it and went to exide. Waaaay better. A necessity on a computerized (efi ) car. Red tops don't hold a charge either. maybe different for a daily driver, but not for cars that sit 2 weeks at a timered top. my exide is killer, love it. sat teh whole canadian winter. cranked right up.
SLO_Z28 11-15-2010 03:44 PM
Actually that makes perfect sense. We have all been there :D
Steve68 11-18-2010 06:52 PM
You mean parallel.
Right, was a busy day, wasn't getting paid to think, weekend,
